02-10-2007, 10:36 AM | #1 |
Sierra Grande Club
rear main seal & torque specs.
I’m going to replace the main seal while the engine is out anyone have tricks to doing a leak proof job?
Also need some torque specs for the bolts. Thanks. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-10-2007, 12:23 PM | #2 |
Re: rear main seal & torque specs.
A tiny bit of silicone on the seal ends and on the main cap mating surfaces at the rear where the pan rubber sits. Also rotate the seal just a bit so it's parting seam doesn't match up with the main cap to block surface.
Someone out there has the torque spec handy....
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 02-10-2007 at 12:23 PM. |
02-10-2007, 12:59 PM | #3 |
Main caps are usually 65 ft. pnds.
02-10-2007, 01:05 PM | #4 |
GEARHEAD
I agree. Oil on the threads then tighten to 45 ft lb both bolt then 70 ft lb
02-10-2007, 02:12 PM | #5 |
Sierra Grande Club
Looks like I need to pull the oil pump too?? Should I get a new one from napa while I’m at it? Any special instructions to replacing the pump?
Thanks for answering my stupid questions; I’ve never done this before. s/t
02-10-2007, 02:21 PM | #6 |
for the 35.00 cost i sure would and did. i love new stuff.
nothing like great oil pressure on your engine for piece of mind |
02-10-2007, 02:39 PM | #7 |
Sierra Grande Club
Do I need to prime this, or is that only needed on new motors?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 02-10-2007 at 04:43 PM. Reason: Didn’t make sense. |
02-10-2007, 04:40 PM | #8 |
Sierra Grande Club
Got the main cap off and the seal was installed so that the ends of the seal were the same as the cap (not slightly off centered like it should be). Any way the one under the crank is easily moved seems like it’ll just come right out, but the one on the main cap is glued. Do I need to glue the new one on?
s/t
02-10-2007, 07:39 PM | #9 |
No reason to glue it, just make sure that the lip on the seal is pointing in the correct direction
02-10-2007, 09:46 PM | #10 |
GEARHEAD
I agree seal will go in either way make sure seal lip is pointing toward the inside of the engine.
02-11-2007, 12:58 PM | #11 |
Sierra Grande Club
Do the two ends need any sealant or will they just seal when it’s tightened up?
02-11-2007, 01:12 PM | #12 |
I've done it with just a miro-spot on the seal ends and without; it didn't seem to make any difference either way.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
