Old 02-10-2007, 11:30 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Water pump swap
I found coolant leaking from the bottom hose of my block yesterday, probably the water pump. How hard is this to do, I dont have much time.
I may have the shop do it, at what price are they taking me for a ride?
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 02-10-2007, 11:45 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Water pump swap
It’s not hard, save the money and do it yourself. Drain fluid, remove fan, remove hose(s), 4 bolts. Clean gasket area install new pump with new gaskets in reverse order. I don’t think I missed anything, its really simple. You can remove the fan shroud to give you more room too.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-10-2007, 01:11 PM   #3
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Water pump swap
just replaced my waterpump on my '71 C20 with a 350. Took a couple of hours, but I went ahead and replaced the hoses and belts since I was in there.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 02-10-2007, 05:46 PM   #4
phlegm
phlegm's Avatar
Re: Water pump swap
Thanks guys, so in a shop 2 hrs plus materials?... I ma in the process of packing my house and moving, not a lot of time for working on ole duke and I need him to pull a trailer.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
