Sierra Grande Club
timeng cover ?'s
I getting ready to put my timing cover on & I need the torque specs for the bolts. Also should I use silicone on the gasket? I have Permatex blue RTV. Someone mentioned using rubber cement, but don’t know about that, seems like it would be a bear to get off later.
I’m hoping that the one-piece oil pan gasket will have torque specs with the instructions, but if you have the info to, that would help. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: timeng cover ?'s
pick yourself up a Haynes manual, Its $14 well spent.
Has all the info, capacities, and torque specs you will need. I have one for every vehicle i've ever owned.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
I know an old mechanic that used weatherstrip adhesive(3M)on covers like that.It acts like rubber cement,very tacky.It helps prevent gasket shifting.
Active Member
Here ya go...
http://www.boxwrench.net/specs/chevy_sb.htm
1969 C10 SWB /350 vortech/th400 1968 SWB build (in progress) 1969 SWB build (my son's future project) 1968 camaro yellow/white stripes (wife's car) 2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's 1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst. 350/350 (sold it ![]() |
#5 | |
Sierra Grande Club
Parts and more parts
Permatex Aviation gasket sealer (red in color) has always worked for me, easy to use and works on all gaskets and metals. Get the small can, so it doesn't dry out on you. RTV is a good thing for the intake manifold valley mating surfaces, but I never liked it as a gasket sealer.
