Old 02-10-2007, 04:56 PM   #1
cheyenne402
3.73 posi rear question.
I have a question about switching rear ends in my 1971 Cheyenne. I have an oppurtunity to get a 3.73 posi out of a 71-72 GMC. The only problem is I have a coil rear in my truck and the posi is a leaf spring. Can I switch gears between the two? My truck is an original 402 big block with 3 speed on the tree. Glovebox does not say what rear ratio I have.
Any help?
cheyenne402 is offline   Reply With Quote
Old 02-10-2007, 04:58 PM   #2
leftcoast66
leftcoast66's Avatar
Re: 3.73 posi rear question.
ya, you can switch gears, but you're gonna need to shim it so that it's setup correctly.
leftcoast66 is offline   Reply With Quote
Old 02-11-2007, 06:58 AM   #3
70GMCer
70GMCer's Avatar
I also believe it depends on what size gears and what size posi carrier you have. Someone else can be more clear this.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-11-2007, 01:58 PM   #4
powell72
powell72's Avatar
I'm assuming you're switching gears and carrier, if that's the case, you'll be fine. If you're switching one or the other you need to find your current ratio, there is a carrier split at 3.73 and up (numerical). Use the pinion shim that is currently on the setup you're getting to get you in the ballpark for install.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-11-2007, 03:15 PM   #5
cdowns
cdowns's Avatar
i'd think i'd be easier and cheaper to weld on the proper brackets than to take apart and reassemble 2rearends
Old 02-11-2007, 04:02 PM   #6
msgross
msgross's Avatar
either way you have a little work ahead of you. I'm doing a carrier swap for my front axle Dana 44. Find a buddy that has done one or the other and go that way. As long as the bearings are good in the donor axle.... Might not hurt to find a shop that has the tools and experience since it would suck to ruin your axle and gears @ 70+ MPH.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-16-2007, 08:35 AM   #7
cheyenne402
ttt
Old 02-16-2007, 09:49 AM   #8
BowTieOgre
If your current rear ratio is 3.73 or above then you have a 4 series carrier, if your current ratio is below 3.73 then you have a 3 series carrier. Either way you should just have to swap the carriers with ring gear attached and shim it right. (easier said than done) If you decide to weld on some axle saddles let me know, ive got a pair im not using anymore. (a good friend talked me out of using a 10 bolt)
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 02-17-2007, 07:50 AM   #9
70GMCer
70GMCer's Avatar
Again, I may be wrong , but if you have a 3.73 gear, you can use either the 3 or 4 series carrier.....Don't mean to hijack here.....
1997 GMC Sierra Ext
1965 Mustang
Old 02-17-2007, 10:44 AM   #10
crazy longhorn
Fabricate till you "puke"
AFTERMARKET, you can get 3.73/4.10/4.56 gears that fit a 3 series carrier. FACTORY, however run 2.76-3.42 on a 3 series carrier, & 3.73/4.10/4.56 are on a 4 series carrier. with the factory gears, the gears & carriers need to be swapped together (accordingly). L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
