computer illiterate
vortec heads
where can i get a new set and what can i expect to pay for them. anyone got a link?
72 2wd blazer 72 swb 4x4 |
Active Member
Re: vortec heads
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
GEARHEAD
Re: vortec heads
![]() Join Date: Dec 2006
Re: vortec heads
Speaking of which,I was just today talking with a builder,John Nijssen of Strokerengine.com and he says that the GM Vortec heads crack pretty easily and to get non-GM heads instead.He said if they get overheated once there're often finished.Anybody else hear about this?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
GEARHEAD
Re: vortec heads
I have heard this also in a few places. BUT BUT BUT these heads a widely used in the circle track racing field with plenty of abuse (High RPM, Over heating issuses.) From what I have seen there does not seem to be a problem IMO. I have built engines useing them they do seem to run a little hotter 5 to 10 degrees at most but with no problems.
Saving 1 truck at a time!
Re: vortec heads
They are very popular here in circle track "claimer" classes as well. Guys run the snot out of them and don't even think about it. They have lots invested in their engines and even though they are "claimers".
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
![]() Join Date: Aug 2004
Re: vortec heads
A guy at work had to replace 1 Vortec head from cracking problems but it was on a super high mileage burban that he overheated several times. He pulled it apart because the head gaskets were trashed and found the cracks when he was cleaning everything up on reassembly.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Feb 2001
Re: vortec heads
I got mine from Scoggin Dicky. Good to deal with and can answer questions. Don't use the cheap gaskets they send you. Get GM or Felpros.
computer illiterate
Re: vortec heads
thanls for the replies i have a buddy that can get them from the local dealer for me at a discounted price of 319 a piece i just wanted to make sure it was a good deal.
GEARHEAD
Re: vortec heads
computer illiterate
Re: vortec heads
there are lots of links which one should i read or should i read them all? i did read up about them on this board and it seems the 062 casting was the better head and that is what he got priced for me.
Active Member
Re: vortec heads
#13 |
computer illiterate
Re: vortec heads
thanks for the link ill call and see what casting that is. by looking at the summit pic i didnt know the vortec heads only have 4 intake bolt holes on each side.
#14 |
Cantankerous Geezer
Re: vortec heads
Chevy high performance has some good articles on the vortec heads.
http://www.chevyhiperformance.com/te...ift/index.html One drawback is the centerbolt valve covers, the aftermarket has come up to speed on them. This also affects wire looms. And you will need the right intake, the bolts run straight up and down on the vortec, versus perpindicular to the head. Some have drilled out the intake bolt holes, but I wouldn't risk the possible manifold gasket leak.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
