Changing oil pan gasket
I need to change the oil pan gasket out in my 350. I am going be taking the motor out to swap out the flexplate and do a few other things. Is this a pretty straight forward swap or is there anything to look out for?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Changing oil pan gasket
get the one piece seal...much easier to deal with. other than that, it's pretty straight forward
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
GEARHEAD
Staight and to the point. If you are comfortable pulling the engine to do the fly wheel swap you should have no problem with the oil pan gasket. make sure what year your engine is and go fo a one piece if you can IMO its a good choice. Also depending on how many miles you have on the engine a rear main seal and oil pump swap may be a good idea for extra insurance while it down that far. Ya wouldn't want to get it back in and have a rear main seal go in the near future very cheap insurance. just my .02 good luck with it keep us posted
NOT REALLY BANNED!
![]() Join Date: Jul 2004
One piece is good, don't use any sealant. You'll be able to reuse it 8-10 times.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Gearhead the engine is a target master crate 350. Gen 1 small block.
Used the 1 piece Felpro...... But they do advise on putting a dab of RTV in the corners of the timing cover.
1997 GMC Sierra Ext 1965 Mustang |
I second replacing rear main seal and oil pump.
oil pan gasket,, felpro one piece
![]() Last edited by rage'nrat638; 07-12-2007 at 06:57 AM. |
Thanks for the pics Mark. Not sure If I will be able to do this with the motor upside down since it still has coolant in it. Probably have to put it up on a stand to do this.
