New cab mounts
How do you swap out cab mounts? Is there a 1 person way of doing it?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
![]() Join Date: Nov 2004
Re: New cab mounts
I did mine by myself. Hyraulic jack and 4x4 wood blocks are what I used. I did them all one at a time and check with a tape measure periodically to make sure the cab didn't shift. When using a jack, keep your hands away from being between the frame mount and cab, in case the jack fails.
The front ones are a pain the ass because they have a spot weld from the bolt head to the cab floor. The back ones are real easy to swap (barring a lot of corrosion to lock 'em up.)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: New cab mounts
How did you position the wood when you pulled the mount?
Re: New cab mounts
Flat against the cab floor outside the frame rails with the jack nearest the mount I was working on. I think I had to stack like 3 of em for the jack to reach.
Re: New cab mounts
or use a chery picker and lift the cab just a bit
Re: New cab mounts
I used a hydraluic jack and a 4x4 like 67 chevy redneck, I had no problems at all I used a 4X4x10" block and positioned it long ways from the jack to the cab. I did one at a time.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
Re: New cab mounts
Do you have to remove the gas tank to access the back nut on the cab mount?
1968 c10 Chevy 2005 Infiniti G35 2006 Subaru WRX STi ![]() |
![]() Join Date: Apr 2007
Re: New cab mounts
You shouldnt have to the nut is in a cage set up but if its rusty and dont come out it might spin in there,then take the tank out and use a vice grip or something similer
Re: New cab mounts
are you doing just the cab mounts or are you doing the ones under the rad support as well? the PO of my truck took the core support ones out to try and lower the front, me and a friend did all six in about 2 hours
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
Re: New cab mounts
piece of cake to do...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
#11 | |||
Union Electrician
Re: New cab mounts
no they are made into the floor
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
