02-11-2007, 04:31 PM | #1 |
Wanted: NEW water pump and wiring harness 1948 GMC 100 Pickup
Hi, I have a 1948 GMC 100 pickup with original straight six cylinder motor and 6 volt electrical system. I would like to switch to a 12-volt system and am looking for a new fuse box and wiring harness. I also am looking to purchase a new water pump. Can you recommend a supplier for these parts? Have tried LMC but they will not guarantee parts will work on a GMC.
Thank You, Chad |
02-11-2007, 04:41 PM | #2 |
Re: Wanted: NEW water pump and wiring harness 1948 GMC 100 Pickup
For the wiring harness I would go with a E-Z wire or It's-A-Snap, if you have any knowledge of DC circuits, if not go with the expensive ones Painless or Advanced I thing they have more info. but you will have all the info you need on the wire every 18"!! For the Water pump I would check with NAPA or someone like Carquest.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
02-11-2007, 04:45 PM | #3 |
Yellow truck club
If you look on the parts board you will find this
http://67-72chevytrucks.com/vboard/s...d.php?t=226748 New wiring harness for sale... Brian ...
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
02-12-2007, 01:46 AM | #4 |
Cantankerous Geezer
I think Jim Carter has the GMC pumps.
www.oldchevytrucks.com For GMC specific forums, try www.oldgmctrucks.com
Fred There is no such thing as too much cam...just not enough engine. |
