08-28-2002, 02:16 AM | #1 |
Hidden antenna?
I have a cowl that is stock with no antenna hole.Where to put a antenna. What a about a hidden one,where and what kind,any idels?
70 short,step on a 72 frame. |
08-28-2002, 04:52 AM | #2 |
Junk Shack,(Radio Shack), has one that ya attach to the inside of your windshield. For the most part, it's hidden from view, and takes only a small hole in dash to route it. Just my $.02
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
08-28-2002, 07:25 AM | #3 |
its all about the +6 inches
You can also mount it under your dash.
Sounds crazy, I know...but it works. |
08-28-2002, 07:47 AM | #4 |
67-72 Addict!
GMC Pauls sells the kind that mount in the top of windshield for $39.95 I think. These type will not work under the dash because the signal will not pass thru metal.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-28-2002, 08:42 AM | #5 |
I have mine on back of cab. Bought it at pep boys.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
08-28-2002, 09:51 AM | #6 |
I use a boat/aviation one that I have under the cowl, works great
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
08-28-2002, 09:56 AM | #7 |
BEST ONE I'VE SEEN IS THE ONE IN THE GAS TANK SPOUT HOLE, BUDDY OF MINE DOES THEM.
AFTER MOVING THE GAS TANK FROM BEHIND THE SEAT, YOU CAN BUY A POWER ANTENNA THAT FITS DOWN IN THE GAS TANK HOLE IN THE SIDE OF THE CAB. THERE IS A LITTLE WELDING REQUIRED BUT THE PIECE IS CUSTOM MADE AND CAN BE ORDERED THROUGH A COUPLE COMPANIES. "IT IS SWEET" |
08-28-2002, 09:58 AM | #8 |
Thats called Freanching in the antana
08-28-2002, 11:22 AM | #9 |
ive thought about putting a retractable in a stake pocket in the front of the bed.
08-28-2002, 11:33 AM | #10 |
I have a late model bed on my 69 and have the antenna in the stack pocket hole.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
08-28-2002, 12:18 PM | #11 |
hidden antenna
AutoLoc selss one from $47.00. It's pretty trick, and is available with a built in amp. It mounts under the dash also.1-800-873-4038 www.autoloc.com.
70 lwb 2wd 64 bug 00 silverado 4x4 00 Impala "SECOND PLACE IS JUST THE FIRST LOSER" |
08-28-2002, 01:48 PM | #12 |
I bought one from rb's auto. I think it is there brand. It was around 45 dollars it think. I mounted it on my back window in the lower corner and ran the cable for it with the dome light wiring. I had to get a longer cord for it. Low68
Build Thread |
08-28-2002, 05:09 PM | #13 |
The antenna mounted under the dash does in fact work. I had mine up in there for a while.
08-28-2002, 05:19 PM | #14 |
Seņor Member
On a '69 I had a few years ago I mounted a standard 31" antenna horizontally behind the grille. You couldn't see it after a quick squirt of flat black paint and it worked great.
Kenneth
08-28-2002, 06:34 PM | #15 |
I ran a insulated copper wire under/behind the rubber windshield gasket at the very top.
I used real small coax cable from the radio then though the small drain hole at the base of the windshield then up to the top of the windshield then ran a 33 inch long unshielded wire horizontal. Hope that makes since :0)
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
08-29-2002, 01:11 AM | #16 |
Thanks everyone. If you could only get this kind of quick and good service out in public we would have it made. Now I have check out these ideals.
