Not a bad nut after all..
FYI: Factory Topless Blazer Side Door Window Opening Caps
I found this pair at a semi-local GM dealer (this is not the same set that was on eBay recently). I was told these parts were discontinued in 1983. Part numbers are as follows:
They are both gray fiberglass (I don't know why the driver's side is black on top). To use them as is requires cutting the entire door frame off. If a person wanted to retain the vent window, these door window opening caps could be trimmed accordingly. I sacrificed an old door with issues to take the pictures due to these requests:
Enjoy! |
Re: FYI: Factory Topless Blazer Side Door Window Opening Caps
Factory Assembly Manual:
sufficiently talented fool
![]() Join Date: Jun 2006
That is Cool!!
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Born Psycho
![]() Join Date: Feb 2001
good piece of info, Bad Peanut
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
its all about the +6 inches
do you happen to have a hi-res scan of that article? I'd like to print that out in full size.
that's cool. the funny part is that you'd think they'd get rid of the door lock
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
I can provide hi-res of all pictures except that one which I borrowed from a previous thread by board member raggedjim.
The LuvShack Garage
I need those
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Hey krue put those in the FAQ.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer Last edited by 65-72 chevytoys; 02-14-2007 at 06:14 PM. |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Moved to the blazer/jimmy board for you.
![]() Join Date: Jun 2002
I'll see if I can get a better scan on the article...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#13 |
#14 |
I'm sorry. I'm having a new roof put on my house and everything that was in the attic is now in my computer room!
Once I find the article I WILL scan it, but so far I haven't found it... Rg
#15 |
Hope this works...
Notice the door caps, no window cranks, and no vent window frame. Also weird is the bench seat and the wide wheels... I wonder if this one is a prototype... Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 02-28-2007 at 02:37 PM. |
#16 |
Hey there is a cool idea. For the trucks remove the gas tank from inside the cab and mount a spare. Well I guess if there is room and you could get it in and out from behind the seat.
Oh well I guess not such a good idea afterall.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
