Old 02-12-2007, 10:14 AM   #1
VTKidder
Which brakes, JD6/JD7?
On my 1986 K20, I need to replace nearly every brake componenet except the booster and MC. I looked up the calipers, and I get the option for JD6/JB6 or JD7/JB7 brake system. The description says it'll show on the RPO label in the glovebox, but that is long-gone. Does one code mean a certain size rotor, or something you can visually tell? Thanks.
-adam
VTKidder is offline   Reply With Quote
Old 02-12-2007, 09:02 PM   #2
beaterC10
Re: Which brakes, JD6/JD7?
Normally the best way to id your brake option is the thickness of rotor and the width of the rear shoes. I don't know what codes correspond to what size, but the parts stores normally can match up with rotors and shoes.
beaterC10 is offline   Reply With Quote
Old 02-12-2007, 10:35 PM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
The rotors on both systems (JB6 & JB7) are the same dimensions. However, the dimensions of the rear drums are different. The JB6 drums are 11.15 x 2.75 whereas the JB7 drums are larger at 13 x 2.5.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 02-13-2007, 07:49 AM   #4
VTKidder
Thank you for the info guys....when I look up the part number on the calipers for JB6 and 7, they are different. Any clue what the difference is?
Old 02-13-2007, 10:14 AM   #5
CookieMonster
CookieMonster's Avatar
cause the front rotors are either 1 inch thick, or 1.25 inches thick.
CookieMonster is offline   Reply With Quote
Old 02-14-2007, 01:52 AM   #6
boxrodz
boxrodz's Avatar
Actually, the thickness of the rotors are the same for both systems. The difference is that the JB6 is a low drag system and the JB7 is a conventional brake system.
boxRODz
