67 laying rocker question
Does anyone know if a 67 short bed will lay rocker without Z cutting the front end of the frame,the front tires will be 275/30/20 and rear 275/40/20
I just finished baggin an 86 and HATE IT!with the same tires the nose stuck up 2" higher than the rear. THANKS FOR YOUR TIME |
Re: 67 laying rocker question
i don't believe it would. you would have to either z the frame or section the crossmember. i'd say just z the frame.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
A guy with a truck
Dropmember. Check the suspension section.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I am a Referee of life.
Be ready to cut on the inside lips of the fender.I know Tim Christians son has his bagged but the fender lips(where the hood sits on the inside) lay on top of the tire before the frame lays out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
dropmember is nice but $$$, i would z the frame and notch the back
dropmember ... save your money and do it right.
