Old 02-12-2007, 11:05 AM   #1
MR MAGOO
MR MAGOO's Avatar
sandblasting question
what is the best material to use in a blaster for cleaning an old rust pitted hood?? i heard sand will warp. is this true. how about metal slag?
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR :hit2: :hit2: 4 WHEEL DISK BRAKES
2000 chevy blazer
1990 nissan pick-up
1984 mazda pick-up (son's project truck)
MR MAGOO is offline   Reply With Quote
Old 02-12-2007, 11:11 AM   #2
suville
suville's Avatar
Re: sandblasting question
If you can find copper slag it will leave a very nice smooth surface, the company that does my blasting and powdercoating uses this and i usually only need a double wet coat of fill primer to achieve a smooth paintable finish
suville is offline   Reply With Quote
Old 02-12-2007, 11:12 AM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Any material can warp a large "flat" surface. The friction of the media hitting the metal builds heat which is what causes warping. If you keep shooting the same place for too long it can really heat up that area and warp the panel. Similar to welding body panels, you have to be very careful not to build too much heat because it will "pop" the panel you are welding on. Point of this story... no matter what you use, keep moving. If you hit a stubborn spot, hit it a little and come back to it (maybe several times).
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 02-12-2007, 11:28 AM   #4
Blue'72
Skinned knuckles
Blue'72's Avatar
I have a cheapie Campbell gun and an old Craftsman hopper that I use on small jobs. The hopper has a screen and I've used play sand with good results. I assume that you'd still need to use safety precautions just like anything else, but I figured that it's cheap enough and more "get it all over your driveway" friendly.. With my compressor, there's enough pressure for small jobs, and like mentioned already, you don't want to use it for large flat surfaces.
I had rust around my rain gutters, so I cleaned out the caulking and blasted it clean. Works really good for the hard to reach areas.
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 02-12-2007, 11:32 AM   #5
cdowns
cdowns's Avatar
sand doesnt warp bad blaster operators warp
Old 02-12-2007, 11:37 AM   #6
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
and some are warped.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-12-2007, 11:37 AM   #7
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Good point. My body man doesn't trust any of them so I make sure the operators know to stay away from the big surfaces. It will almost always take less time to clean the surfaces the "slow" way (i.e. grinding) than to try to fix heavy warping on a large surface, especially a hood.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 02-12-2007, 01:59 PM   #8
CMars45000
CMars45000's Avatar
Out of all the abrasives out there, I like Aluminum Oxide the best. My buddy has a full-blown blasting operation with roll-in booth and that is what he uses for frames and bodies...He even TRIED to warp a hood once and had a VERY hard time doing it...
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 02-12-2007, 06:08 PM   #9
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Anybody ever used baking soda?
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 02-12-2007, 06:13 PM   #10
cdowns
cdowns's Avatar
good for biskits and cake// can leave residule which ends up like battery acid eating stuff away /major paint companies wont warrentee paint on a soda blasted finish
Old 02-12-2007, 06:21 PM   #11
timzrides
timzrides's Avatar
Where might be the best place to buy these different abrasives. Such as a local hardware store of some sort??
timzrides is offline   Reply With Quote
Old 02-12-2007, 10:23 PM   #12
Bamm
Bamm's Avatar
Thanks cdowns, I had heard about using it, didn't realize there would be paint issues. Appreciate it............Jerry
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
