![]() Join Date: Feb 2001
Help Identifying Hubcaps
Hello all. I'm usually over on the 67-72 board, but I was wondering if you all could help me identify the years for these 3/4 ton hubcaps. I'm guessing they were 76-87 or maybe 77-87. I've got a set of NOS ones to sell and I would like to know exactly what years they are correct for. Thanks!
'72 Chevy Blazer |
Professional Grade
Re: Help Identifying Hubcaps
I had a set just like those on my 74 3/4 ton
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
yeller
Are you sure they are 3/4 ton? What is their diameter? 1/2 and 3/4 ton caps look alike, but are different in size. I can't be of much help on the year break however.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
The One And Only !!!
LMC has them as 76/87 and WOW 59.95 each.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
I thought the 3/4 ton caps had a 6 "spoke" pattern and the 1/2 ton caps had a 5 "spoke" pattern like those pictured.
I have a set I pulled off a '86 Chev 1/2 ton 4x4 that look like that, but not nice like that. I am pretty sure they were stock on the truck.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
67 is sold
My 1985 1/2 ton 2wd Chevy had those caps with stock white wheels
Looking at the pics in the LMC catalog the 5 "spokes" are way deeper than the 6 spoke which would lead one to believe the deeper 5's would be the 3/4 ton and possibly 1/2 ton 4x4 due to the front hubs.
The Crazy Machanic
I had a set on my d0nor 4x4 it was a 1 ton 1983
I believe what you have is the 1/2 ton caps. I had a set like this on my 74 Cheyenne 1/2 ton. But I see two sets of the 5 spoke design like yous on ebay being advertised as 3/4 ton caps.
Here is a same vintage six spoke 3/4 ton cap, which is about 12 inches wide: Last edited by Texasdeere; 02-12-2007 at 09:58 PM. |
Since I blew the on-line pic up they are listed as 1/2 ton.
Thanks very much to everybody for the help.
'72 Chevy Blazer |
