69 control arms?
What other year upper control arms will work on my 69.?
Designated A-hole!
Re: 69 control arms?
Also are 3/4 ton control arms the same as 1/2 ton?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Dave's not here, man
The LMC catalog says that all 1/2 ton 2WD 67-72's had the same control arms upper and lower. It lists 3/4 ton 71-72 as a different part, but I don't understand why they don't have a 3/4 ton listing for pre-71 trucks.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Try this thread but we didn't get any more info either.
http://67-72chevytrucks.com/vboard/s...d.php?t=225837 |
#5 | |
Who's got steelies?
![]() Join Date: Feb 2006
According to LMC: 67-72 1/2 ton control arms are the same part as the 73-87 3/4 ton control arms. They use the same cross shafts and end nuts. The later 73-87 1/2 ton arms are different and have rubber bushing instead of the threaded metal end nuts like ours.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Are the arms with the big threaded end nuts better than the later ones with the rubber bushings, washer & nut?
55 Chevy small window. 66 FJ40 LandCruiser. 64 Chevy Van,350/350 72 Chevy 10 Van,short wb,454 78 Chevy 10 Van,short wb,350 72 Chevy Malibu 350. 77 Chevy Suburban. Silverado 20 Trailering Special.454,turbo400. |
#7 | ||
i did a post similar to this a little while back and found out that 67-87 3/4 and 1/2 ton upper control arms identical but lower control arms are differnet do to ball joints (other than that athey are also identical). Gm changed the design of there spindles in 73 to a shorter version so they used taller balljoints, and they also changed the tie rod diameters and lenghts.
