Old 08-28-2002, 10:08 AM   #1
R&R
need bracket that holds the kick-down cable
I need the bracket that mounts on the manifold that that holds the kick-down cable. It's for my BB. Thanks.
'68 C/10, SWB, 396/350, PS, PB, A/C
'68 C/10, SWB, 400sb/350
R&R is offline   Reply With Quote
Old 08-28-2002, 11:06 AM   #2
tom hand
CCRider
tom hand's Avatar
Your sig says you have a 400 trans, why do you need a kick down bracket? For the most part 350 transmissions never came behind big blocks so I don't know if GM ever made one. So I would think your choices are to modify a small block bracket to work or get an after market one from summit that mounts on the carb. Spectre part# SPE 2428
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 08-28-2002, 02:46 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
TH 400's used an electric kickdown switch, either mounted to the carb(pre 71) or mounted to the gas pedal 1971 and up.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-28-2002, 03:00 PM   #4
COBALT
COBALT's Avatar
Since you're only asking for a bracket I assume you already have the switch, correct? You should have power coming through the firewall via a gromet from the fuse block (red wire), and an orange wire coming up from your transmission (goes to detent solenoid inside transmission). Both of these hook to the switch.
Since you're pre '71 your switch probably mounts to the carburetor. You'll probably need the ones in the lower right-hand corner of this pic:
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-28-2002, 10:19 PM   #5
R&R
Thanks for the input, guys. I was told when I bought the truck that it had a 400, but come to find out it has a 350. The engine or tranny was swapped somewhere down the line. The option sticker is gone from the glovebox. Will that be a problem for the 396?
Old 08-28-2002, 10:32 PM   #6
tom hand
CCRider
tom hand's Avatar
How long it will last will depend on how heavy your right foot is. It will basicly last as long as any 350 if you just drive it normally, but a big block will be hard on it if you drive it hard. I wouldn't just pull it out, but if it has a short life span you might think about replacing it with a 400. Good Luck!
Olive Branch MS
Old 08-28-2002, 10:38 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There were some big block TH350 trucks produced.
