Old 02-12-2007, 05:55 PM   #1
billy37380
Junior Member
power steering question
i have a 69 chevy c10 i am wanting to add powersteering to my truck what would i need to do this to switch mine over
billy37380 is offline   Reply With Quote
Old 02-12-2007, 06:04 PM   #2
short69
short69's Avatar
Re: power steering question
many companies sell complete p/s kits usually around 7-8 hundred bucks, or, if you wanted to aquire all the parts seperatly you need... new gear box, p/s pump, mounting brackets for pump, new pitman arm, hoses, and a new rag joint. you can pull a lot of this stuff off of donor trucks, I think they are all the same on 71-87 trucks but i am really not positive.
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 02-12-2007, 06:25 PM   #3
jimmydean
jimmydean's Avatar
I got everything for mine off a '75. The only thing I had to do was notch the bumper bracket a little to clear the end of the gear box (15 minutes with a grinder). Not all 69's will need to be notched, but you will know when you look at it.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
