Old 02-12-2007, 08:03 PM   #1
GREASEMONKEY72
GREASEMONKEY72's Avatar
engine specs
i did a search but didnt find what i wanted and that is the stock engine specs for a 72 350sbc 4bbl, such as horse power at rpm and torque at rpm
and i looked at the mortec site and didnt find my block number which is: 8970014
head number is: 8978487X
so im looking for any and all specs that anybody has to offer with the block and head numbers and any ratings and also the cam specs and anything else anybody can think of
also whats the cfm rating on the stock quadrajet
basicaly im looking for any and all specs i can get ahold of
THANKS IN ADVANCE
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-12-2007, 08:18 PM   #2
65-72 chevytoys
65-72 chevytoys's Avatar
Re: engine specs
Crate motor or aftermarket heads? CFM on a stock Qjet is about 795
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 02-12-2007, 08:25 PM   #3
bigjimzlll
bigjimzlll's Avatar
Re: engine specs
3970014....350...70-76...2 or 4
Believe me this is your block....the first 3 does look like an 8
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-12-2007, 08:28 PM   #4
GREASEMONKEY72
Re: engine specs
stock block and heads
thanks for the cfm, would the number on the carb make a difference?
-steven
Alte Seele S.S.
Old 02-12-2007, 09:45 PM   #5
GREASEMONKEY72
Re: engine specs
so what i think is an 8 for the first number is a 3 on the block number???
and for what its worth heres the number on the side of the carb: 7042206 QA 0282
-steven
Alte Seele S.S.
Old 02-12-2007, 10:20 PM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
Re: engine specs
You should definitely send for the GM restoration package mentioned in another thread here recently.It has all the juicy data for your year truck.
I can tell you though,all the 350s had the same cam up to '86 that had .398 lift on int. and I think .410 exhaust (although my GM service manual has both listed as .398).
Added: Duration was 195/202 @.050 I believe.112 deg.C.L.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 02-12-2007, 10:21 PM   #7
timcos
Chief Honcho In Charge
timcos's Avatar
Re: engine specs
Stock specs on a 350 4bbl is 175 HP
Max tourque is 292 ft/lb
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 02-12-2007, 10:37 PM   #8
CrashEd
72 chevy
CrashEd's Avatar
Re: engine specs
If you can get the # off the front pad it will tell you what it is. well we can look it up for you. Most 350s that come in a truck are 175 horse power@4000 rpm and 280 torque@2400rpm. Thats net horse power before thay went to SAE standards in 72 it would be 250 horse power for a 350 4 barrel
Ed
CrashEd is offline   Reply With Quote
Old 02-13-2007, 12:25 AM   #9
GMCMAX
Active Member
GMCMAX's Avatar
Re: engine specs
On my 69, 350 w/quadrajet 240hp
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 02-13-2007, 12:26 AM   #10
GREASEMONKEY72
Re: engine specs
the number infront of the head is V048TFD
and yea i remember the thread about the restoration packet and ill make sure i call them for it, i completely forgot about that
THANKS FOR ALL THE HELP GUYS
-steven
Alte Seele S.S.
Old 02-13-2007, 12:30 AM   #11
GREASEMONKEY72
Re: engine specs
now i cant find the thread with the number plus i forgot the title of it, could someone post the link or just post the number please?? thanks
-steven
Alte Seele S.S.
Old 02-13-2007, 12:40 AM   #12
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: engine specs
Here you go...
http://67-72chevytrucks.com/vboard/s...d.php?t=225355
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-13-2007, 12:45 AM   #13
GREASEMONKEY72
Re: engine specs
THANKS FarmTruk, ill give them a call tomorrow
-steven
Alte Seele S.S.
Old 02-13-2007, 01:24 AM   #14
bigjimzlll
bigjimzlll's Avatar
Re: engine specs
TFD 1955 265 a/t 180 4 truck/1500
TFD 1956 265 a/t 205 4 truck/1500
TFD 1957 283 Powerglide 245 8 truck/1500
TFD 1972 350 conv.cab, 175 4 C-10 & 20
TFD 1982 350 conv., van & bus L LS9 155 4 C-10 to 3500
Anderson,CA
Old 02-13-2007, 02:03 AM   #15
CrashEd
72 chevy
CrashEd's Avatar
Re: engine specs
TFD is a 72 350 with 175 horse power c/10 c/20 truck.
Old 02-13-2007, 02:09 AM   #16
GREASEMONKEY72
Re: engine specs
whats TFD?
-steven
Alte Seele S.S.
Old 02-13-2007, 02:14 AM   #17
CrashEd
72 chevy
CrashEd's Avatar
Re: engine specs
V048TFD The letters at the end of your # on the front pad, That tells what it went in and horse power
V= flint the factory it was made 04 it was made in the 4 month 8= 8th day of 1972
Old 02-13-2007, 02:20 AM   #18
GREASEMONKEY72
Re: engine specs
i knew that
thanks though
-steven
Alte Seele S.S.
