Old 02-12-2007, 09:41 PM   #1
gregbr
Senoir Member
gregbr's Avatar
Stainless Exhaust system??
Has anybody installed a stainless steel exhaust system? What mufflers do you use and how do they sound? I'm thinking about SS for my 70 GMC with a 402. I want the bigblock to sound good, but not loud or give me that resonance that gives a headache. The SS mufflers I've seen don't give a clue what they sound like. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 02-13-2007, 09:58 AM   #2
Ozona
Re: Stainless Exhaust system??
I ordered one for my big block '72 from Stainless Works. 3" SS from the headers back and they recommended their two chamber turbos when I told them I didn't want small children and animals to run when I started the truck. Basically my wife will drive it - she loves rumble/some thunder, but she won't drive it if it's too loud.
Seem solid to deal w/ so far, they do have some lead time...and the bill was a little ugly - but SS won't ever rust out and it's mandrel bent very nice stuff.
Jury is out...I'm confident at this point..and hoping.
Ozona is offline   Reply With Quote
Old 02-13-2007, 12:50 PM   #3
Dean
Dean's Avatar
I've put stainless on both my 71K20, 72K20 and hopefully this weekend on my 87 K30. I've bought the muffers from Allen's stainless who supplies a lot of Corvette stainless exhaust. I just bought the stainless pipe and had a friend bed it all and install it with my help. It helps to know someone with the talent and equipment. I used stainless weld wire and clamps as well. They are pretty quiet except for the first one I did with Borla muffers with were to loud and I wound up adding another muffer on each side. And I agree they should last forever.
Here are a few pics of the 71 K20 with the stainless being installed. I used original manifolds and size pipe as original on this one. The 87 K30 with the 572 is getting the same thing but with 2 1/2" pipe.
And I agree it isn't cheap but worth it if you are going to have your truck for a long time.
Dean is offline   Reply With Quote
Old 01-26-2008, 04:04 AM   #4
gregbr
Senoir Member
gregbr's Avatar
ttt
Old 01-26-2008, 04:05 AM   #5
Jim_PA
I have the stainless magnaflow kit w/Thorley headers in my garage, I paid $400 on Ebay for the header-back kit. Looks very nice.
Jim_PA is offline   Reply With Quote
Old 01-26-2008, 04:37 AM   #6
Classic69
Love That '69
Classic69's Avatar
Magnaflow or Borla offer stainless steel exhaust kits.
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 01-26-2008, 04:54 AM   #7
haysonj
haysonj's Avatar
I put the 2 1/2 in true-x magnaflow on mine had to rework front to miss transfer case
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-26-2008, 06:06 AM   #8
whatnow123
whatnow123's Avatar
So I'm assuming you haven't put it on yet?
If you have, any issues? I'm looking to do this as well.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-26-2008, 06:11 AM   #9
whatnow123
whatnow123's Avatar
Build thread:
Old 01-26-2008, 09:04 AM   #10
Jim_PA
No, haven't put it on yet. I studied the pics found here: http://www.classictrucks.com/tech/06...ion/index.html for a while, and it looked fairly straightforward. I was pretty impressed with it from their article though.
The only thing that is questionable is my z-bar with the headers. I'll find out in the next week or so.
Old 01-26-2008, 09:21 AM   #11
stope4
I looked at installing stainless on my 68 camaro and concluded that it wasn't worth the extra expense. With the improvement in exhaust piping over the years, I'm not sure a stainless exhaust system will last any longer than a regular exhaust system. I also think stainless starts looking different with the heat. As for mufflers, you can put any muffler on the system. Mufflers tend to be cheap and the newer ones seem to last a very long time. Plus, if you don't like the way it sounds, the expense to you won't be at the cost of a stainless muffler. My 95 pickup daily driver still has the original muffler on it. It looks dirty but it doesn't look rusty on the outside. Either way, I don't think todays regular exhaust piping can be compared to what was installed in the late sixties and early seventies. For some reason it seems to be better metal and improved galvanized or aluminum coated today. Someone reading this may be able to give more on today's products and the qualities.
Now, if your truck is going to be a show truck, stainless may be the way you want to go.
stope4 is offline   Reply With Quote
Old 01-26-2008, 11:52 AM   #12
67wes
I put the 2 1/2" magnaflow system on my truck and I love it! You will have to have to cut it by the collector and weld on the collector end and two hangers will have to be welded on but its easy. The nice thing about the kit is that you can unbolt it like I have done to do my frame off resto. Its very quiet.
67wes is offline   Reply With Quote
Old 01-26-2008, 02:21 PM   #13
Jim_PA
Good, my truck is so obnoxiously loud, I can't wait to get this on Got any pics? Might give me some inspiration
Old 01-27-2008, 08:18 PM   #14
gregbr
Senoir Member
gregbr's Avatar
Thanks for the replies. I'm looking at 2 1/4" Stainless with 50 series Flowmasters. System will be custom made/installed in Charlotte NC....around $600 is the guesstimate. Greg
Old 01-27-2008, 09:15 PM   #15
Jim_PA
You need at least 2 1/2" for a 402.
Old 01-27-2008, 09:49 PM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have Magnaflow SS Mufflers on GQ, the shop that did mine did not offer SS pipes
at the time. I have Hedman "Elite" Headers (3/4 Length) no tailpipes or tips, just a
set of turndowns in front of the rear wheels. Video below is a sound clip of mine, I
have approximately 425 hp and the Blazer is in the garage, the camera is out in the
driveway, so it sounds a lil bit tunneled. (Ignore the dog barking in the background)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-28-2008, 02:24 AM   #17
gregbr
Senoir Member
gregbr's Avatar
GQ sounds pretty good....nice cam.
What's the largest pipe that will fit in the flange piece on a BB with factory manifolds. I have 2 1/4" now, looks like no bigger than 2 1/2" will fit. Greg
Old 01-28-2008, 07:56 AM   #18
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
TY, I have 2.5" on mine, the chart below is from the Flowmaster Dealers book
Old 03-07-2008, 10:17 PM   #19
gregbr
Senoir Member
gregbr's Avatar
Finally got the stainless exhaust system...... 2 1/2" stainless with 50 series delta flowmasters. They had a heck of a time getting the bends over the axle without crimping the pipe. But, it sure sounds great. Any idea why the drivers side pipe is hotter at the rear? Passenger side does have the heat riser valve. Greg
