Old 02-12-2007, 09:43 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
1989 tilt column........will it fit in a 1978?
I have been doing projects on 67-72 trucks for a while now and had the opportunity to score a 1978 loaded Silverado 4x4 with 73K actual miles!! what a nice truck...anyway it doesn't have a tilt column and I have a chance to get a nice tilt out of an 89 suburban...will it fit? what mods do I have to do if not? Thanks for your advice in advance, since it's my first foray into this generation of chevy trucks!!
Jim
jcfoote60 is offline   Reply With Quote
Old 02-12-2007, 09:47 PM   #2
ureckme
ureckmefixit2@cox.net
Re: 1989 tilt column........will it fit in a 1978?
Just put it in
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 02-12-2007, 10:08 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Physically it will bolt right in, But I read a while back about a guy doing this type swap and the ignition and turn signal switch plugs were different on the later column, He ended up re-doing the harness plugs.
LMC breaks the switches 73/87.
Just something to make sure of before you purchase.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-12-2007, 10:14 PM   #4
Russell
Professional Grade
Russell's Avatar
Also note that your truck has the wiper switch on the dash, and the headlight switch on the floor, while the 89 will have both on the signal light stalk. It can be done, but expect to change some wiring around...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-13-2007, 08:21 AM   #5
jcfoote60
Active Member
jcfoote60's Avatar
Hmmm.........good points on the wiring. I wonder if the 89 also has intermittant wipers on it? I would imagine a guy would need to get the wiper motor to match though. this might be an interesting project.....or I can hold for an earlier model tilt
Old 02-13-2007, 12:50 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Other than the above listed wiring issues, it will physically bolt in, especially if it came out of a burb.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-13-2007, 01:06 PM   #7
bigblock73
yeller
bigblock73's Avatar
I would get an earlier model tilt for ease of installation...they are plentiful around here and on ebay.
bigblock73 is offline   Reply With Quote
Old 02-13-2007, 07:46 PM   #8
Restrorob
Restrorob's Avatar
Yep, Picked up mine on ebay for $60 including shipping....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
