Old 02-13-2007, 01:21 PM   #1
jeff1vol
jeff1vol's Avatar
Temperature problem! Need help...
My temp. gauge keeps fluxuating to hot and back down to normal, but the engine does not seem to actually be running hot (no steam, etc.)!? As long as the truck is moving the temp will hold steady, but if I stop for a period of time with the engine idling, the temp. will start going up and down again.
Is this a bad thermo? Is there a sending unit that may be bad? Have any of you guys had similar trouble. The engine is a GM 350.
Thanks,
Jeff
jeff1vol is offline   Reply With Quote
Old 02-13-2007, 01:37 PM   #2
bobthecop
bobthecop's Avatar
Re: Temperature problem! Need help...
sounds like the thermostat is closing early and opening late. That would be my guess, or a flow restriction.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 02-13-2007, 02:05 PM   #3
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
Could be a partially plugged radiator (flow restriction) or even low on coolant. Is the radiator actually full????
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 02-13-2007, 03:18 PM   #4
sb69chevy
sb69chevy's Avatar
A radiator hose isn't bad is it? That was my problem once. Thought it was the thermostat, changed it but neglected the hoses. Ran well for a day, then blew the lower rad hose off. Just a thought.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 02-13-2007, 03:21 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that sounds like classic sticking t-stat, or low coolant level.
Old 02-13-2007, 04:12 PM   #6
Rick Mills
Rick Mills's Avatar
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 02-13-2007, 08:12 PM   #7
cooters
is your sender on top of the thermostat housing? This would happen in that case. Otherwise it seems to be a thermostat problem
cooters is offline   Reply With Quote
Old 02-14-2007, 04:00 AM   #8
GREASEMONKEY72
GREASEMONKEY72's Avatar
whens the last time you changed the t-stat? because just like everyone has said thats most likely what it is
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-14-2007, 03:56 PM   #9
jeff1vol
jeff1vol's Avatar
Thanks ya'll! I'll check the levels soon. I know for
sure its not a bad hose. I just replaced both about 3 months ago. If the coolant level is appropriate, I'll just get a new thermo and try that out.
Thanks again for your responses.
Old 02-14-2007, 06:00 PM   #10
see ten
WTB this ad
see ten's Avatar
Don't forget the resistor on the back of the cluster. My K10 had similar symptoms that went away when I swapped the resistor. If you can borrow an infrared thermometer from someone you can check your actual temps when the needle starts to climb.
see ten is offline   Reply With Quote
Old 02-15-2007, 03:43 AM   #11
hvychve
To The Levy
hvychve's Avatar
what about the wire from the sender to the gauge, is it intermittantly shorting out ?
hvychve is offline   Reply With Quote
