![]() Join Date: Apr 2003
71-72 gas pedals $15
71-72 Gas pedal $15 ea plus shipping
Junior Member
![]() Join Date: Dec 2001
Re: 71-72 gas pedals $15
Can you check shipping to 64123. I would like to convert my 70 to this style pedal. Couple of questions, does this style use cable versus rod? Whats the difference in left one and right one?
68 SWB all over the garage 86 LWB silverado 2006 silverado SS |
These do use cables. the one on the left can be used with a 400 trans, the kick down switch bolts into the square hole. I`ll check shipping for you this evening when I get back from work. Woody
I have a 68 with the older style pedal (bottom hooked to floor) and would like to switch to this kind. Do you know what all would be involved? Also, my truck has a 350 in it w/ a 3pd auto. Eventually, I will probably go 700R4 or similar. So, would the one on the left work for me or would I be up for a bunch of fabrication either way?
snohog- Shipping will be $10.84
doobiebrother-Either one will work. Not a lot of fab work, drill four holes, three to mount the pedal, one for the cable (you will have to use a flat file or die grinder to square this hole for the cable to lock into) I dont have the cables or bolts to mount the pedals. |
Junior Member
I'll take the one on the right, looks to be in the best condition. Do you paypal?
Junior Member
Paypal for $25.84 sent, thanks.
snohog- your pedal is on its way. Thanks, Woody
