Old 02-13-2007, 05:46 PM   #1
Duro5341
Duro5341's Avatar
86 K10, pulls right under hard braking
Hey guys
My 86 K10 pulls to the right while braking hard. I don't notice it normally, but I am very easy on my brakes. It has newer calipers, pads, and machined rotors on the front
It's not something I am terribly scared about, more of an annoyence.....
I am wondering if it is the MC, or the proportioning valve.....being the lines look good, and I am not loosing any fluid at all
Cameron
Duro5341 is offline   Reply With Quote
Old 02-13-2007, 06:12 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 86 K10, pulls right under hard braking
could be alot of things but if the calipers are both good and the pads are wearing evenly id also check to make sure that the wheel bearings are good then the proportioning valve
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-13-2007, 07:06 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Could be a brake hose collapsing internally causing a restriction in fluid flow to one side, Have seen that a couple times.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-13-2007, 09:02 PM   #4
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
I strongly agree with RestroRob. I ran into the same thing a few years back w/ my 83. If that's what it is, expect it to get worse.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 02-13-2007, 09:09 PM   #5
Crank
Crank's Avatar
Hey... what do ya know.. mine does the same thing, well my C10 does, it pulls right on hard braking... so guess what I do... STEER LEFT!
Brandon
Crank is offline   Reply With Quote
Old 02-13-2007, 11:14 PM   #6
Restrorob
Restrorob's Avatar
Brandon
Bet that's fun on wet roads....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-14-2007, 07:57 AM   #7
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: 86 K10, pulls right under hard braking
Yeah it sounds like a brake hose issue i had a '92 S10 that did that and it was a bad hose on the drivers side.
If you replace the hoses i'd go with a set of Earls SS Braided ones i'v got them on my '87 and it's been at least 10 yr's now and no problems yet and they give a much firmer pedle cuz theres no hose flex under braking pressure.
Good luck
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-14-2007, 08:01 AM   #8
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
I had the same problem... and it ended up being the rubber lines breaking down internally. If it pulls right; then you need to replace the left side... and vise-versa if it pulls to the left. I recommend changing them both at the same time... if you dont; you'll be under there again soon.
Anthony
CLASSIC87' is offline   Reply With Quote
Old 02-14-2007, 09:51 AM   #9
PhilaTruck
PhilaTruck's Avatar
Anthony
Good point, Anthony. If one side's not getting fluid, the other side pulls. Seems backwards.
Subscribe here!
Old 02-14-2007, 12:08 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
Check or replace the front brake hoses, would be my vote. I have had that happen on a couple trucks.
piecesparts is offline   Reply With Quote
Old 02-14-2007, 02:07 PM   #11
slugish
Slugish
My 84 does same thing. because of advice from all of you will be replacing my brake hoses soon also. seems like a common problem with these trucks.
slugish is offline   Reply With Quote
Old 02-14-2007, 04:52 PM   #12
KShortell
KShortell's Avatar
I had a weird left-then-right-then straight thing a few years ago myself. New front hoses and calipers solved it. I believe the calipers were shot and I ran throught pads more quickly than I shouldv'e been.
Rebuilt calipers were $15 each at NAPA and new hoses ran about $30 per side. It's been fine ever since.
-Kevin
1986 C10 Suburban Silverado
Semper Paratus
KShortell is offline   Reply With Quote
Old 02-14-2007, 10:23 PM   #13
86k10
I had that trouble with mine too until I replaced the calipers.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 02-14-2007, 11:07 PM   #14
method2mymadnes
method2mymadnes's Avatar
I have had the brake hose and the caliper cause this before.
87% of all statistics are made up on the spot.
method2mymadnes is offline   Reply With Quote
Old 02-15-2007, 07:15 AM   #15
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I vote new brake hoses. As stated above they are probably internally coming apart.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-15-2007, 02:21 PM   #16
VTKidder
Had it happen on my '69 Z/28. Pulls hard to the right on braking; many have told me its a front hose, but its one of those "round to it" things. With 37" of fresh snow....brakes on a summer cruiser isn't really priority 1.
I respectfully disagree with 87 Stepper on the hoses. I'd just pick up OEM replacement rubber hoses from a parts store. I've always thought that SS lines were more for high-performance, heavy duty braking systems where you really need to feel the pedal, and expansion cannot be tolerated, like racing. In a 20 year old 4x4 truck...I'd save my money and just get the rubber lines and worry about it again in another 20 years.
VTKidder is offline   Reply With Quote
Old 02-16-2007, 07:00 PM   #17
Duro5341
Duro5341's Avatar
Well I will just replace both front hoses, and I will just be getting the standard rubber hoses from our Jobber, and put them on at the shop where it's warm, and I have a hoist.....So far everything including belts, and hoses have been original on this truck, so I would assume the front flex lines are aswell, 21 years is old enough to retire them, they've done there job well
Duro
Old 02-16-2007, 10:44 PM   #18
PhilaTruck
PhilaTruck's Avatar
Warm, good. Cold, bad. Good for you for having a heated shop. Mine were a real bear. They rusted on- had to heat-em up to get them off. Careful around the gas lines on pass. side.
Subscribe here!
