Body filler questions?
I have most of my truck in bare metal, and all the welding is done, so now I need to do some minor filling. I am using the yellow filler with the blue hardener. It dries a lime green color, but I can't think of the name. It's like Rage Gold. Anyways, I was wondering if I apply it to the bare metal, or if I have to prep it with something first? It is on the roof top and rear, the lower body like the cab corners, etc. Any help would be great. Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
Re: Body filler questions?
Just scuff and clean the metal and apply. Rage Gold is good stuff.
the rougher the body, the better the stick. Prep area with 40 grit for best bite
Remember rust is happening weather you see it or not, so make sure to 40, or 80 grit where the mud is going.
![]() Join Date: Jul 2006
Yep everyone is spot on so far...I would just wipe it down really well with some autobody prep cleaner then scuff with 80-grit or coarser, wipe down again, then slap on the mud...
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
Sounds like I was thinking the same thing as everyone here. Thanks guys!
A guy with a truck
Not to go against the grain, but...
If you're down to bare metal, might as well put an epoxy primer on it. This will seal the metal very well preventing further corrosion, and you can apply filler over it. My $.02 -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
If I remember right after I sandblasted everything we put on a coat of some neutralizer stuff, cant remember what it was really, i think it was bluish/greenish. Then epoxy primer. But that was for the entire cab, so you might be fine if its just some spots.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
i would put either epoxy primer or etching primer to seal the bare steel to prevent any rust or corrosion from happeneing, but you should be able to just scuff it and pud the mud right on the steel like all have said, goodluck with it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
