Old 02-13-2007, 08:45 PM   #1
muddpile
muddpile's Avatar
Sound deadener questions?
I'm getting closer and closer to finishing this truck, and the more I think about it, the more sound deadening has me worried. I had to replace a LOT of rust (see my build thread, it was bad...) and with this stuff stuck all over it, what happens if it rusts again. I did my corvette with it, and it worked GREAT, but it's made of fibreglass so rust wasn't a concern. I suppose the truck was driven in winter, on gravel and stored outdoors, so that's where the rust came from, but it still is a concern of mine. What do most of you guys reccommend? I don't have an in-cab tank anymore, and will be building a rear cab cover. I have 70 Square feet of brown bread sound deadener from B-Quiet. Thanks!
muddpile is offline   Reply With Quote
Old 02-14-2007, 11:04 PM   #2
mnunn454
mnunn454's Avatar
Re: Sound deadener questions?
I'm getting ready to install FATMAT in mine. Like yours. it has the tank out too.
All I'm going to worry about is making sure the metal is all well primed and painted before mounting the deadener. Putting plenty of thermal insulation on top of that and under the carpet should minimize any moisture collection that may be caused when the floor gets cold enough to cause any condensation on the inside.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 02-15-2007, 12:39 AM   #3
jimmydean
jimmydean's Avatar
I am rolling POR-15 on my floor before I install the deadener. I hope that it will stifle rust at least for a few more years.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
