02-14-2007, 05:26 AM | #1 |
Rear wheel wells
My 71 Burb has rust holes in the rear wheel wells, right at the seem of the wheel tub halfs. What is the fix, remove the seem and replace with new metal . How hard is it to remove the wheel tub. Do they sell new ones. Is the truck same. any info would be great.
02-14-2007, 09:23 AM | #2 |
Re: Rear wheel wells
The tubs just unbolt. Truck ones are different. Post a WTB ad, you should be able to find some pretty easily.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-14-2007, 11:50 AM | #3 |
Hey Rob, Do they unbolt as one piece or two. Is it attached to the quarter panel in any way. Thanks for the input. John
02-14-2007, 12:56 PM | #4 |
Old School, New Style
They unbolt at the floor lip and are spot welded along the seam. Sometimes the carraige bolts are hard to undo. I have found sometimes if the bolts are real rusty it is easier to tighten them to break them rather than fight with loosening.
Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
02-15-2007, 01:49 PM | #5 |
Not knowing how much rust repair is needed on your tubs, I would still look at repairing them instead of replacing them. When we replaced my son's Burb tubs we removed the floor to get access to the tubs and side walls. Even with the floor out of the way it was a chore to get the tubs out. In addition to the tubs being welded in at the lips of the wheel openings, there is a brace that is welded on top of the tub(s). It is a tight fit and the replaced tub has to be worked into place.
Here is a pic of the Burb with the floor out and the tubs removed. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
