Old 02-14-2007, 03:49 PM   #1
Ozark Tim
Ozark Tim's Avatar
How did factory route 72 tach wire?
What I really need to know is which round, cardboard knock out next to the fuse block is the one that the factory used to route the tach wire through. There are three of them stacked and even though any would work o.k. I would like to route it the same way the factory did.
Does anyone have a 72 that could look and say top, middle or bottom?
As always thanks for the assistance!
OT
Ozark Tim is offline   Reply With Quote
Old 02-14-2007, 06:19 PM   #2
JimKshortstep4x4
Re: How did factory route 72 tach wire?
The factory tach wire was routed through the hole between the fuse panel
hole and the e-brake hole. Here is a picture of a 72 firewall with the factory hole for the tach wire. The hole is 3/4" and on this firewall the hole was punched and not drilled. (There are four dimples for locating the hole(s)).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-15-2007, 12:06 AM   #3
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
There is a good picture in the Assembly Manual, if you have one.
PICKMUP is offline   Reply With Quote
Old 02-15-2007, 09:59 AM   #4
Ozark Tim
Ozark Tim's Avatar
Thanks for the picture reference! That is exactly what I needed!
OT
