Front suspension rebuild
I'm getting ready to order parts and wondering if I should go with original bushings or poly. I plan on ordering most parts from ECE, but they don't supply 3/4 ton springs. Any ideas where I can order bushings, springs, shocks?
Also - are there any pitfalls I may run into changing out the front end parts? Thanks!
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI ![]() |
Re: Front suspension rebuild
alot of stuff is over the counter stuff at most local parts stores with no cost for shipping
Junior Member
I purchased all my stuff at the local parts store for just shy of $400 and it was all moog parts.
#4 | |
![]() Join Date: Nov 2004
![]() As far as the springs... I dunno?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-14-2007 at 06:31 PM. |
#5 | |
I may be wrong and I'm not sure what front end you have, but the 67/72 doesn't use rubber bushings in the front, the later front ends do, I think, that's why I'm saying this. The trailing arms have rubber bushings, the front uses some sort of metal screw in bushings with a rubber grease seal.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 02-14-2007 at 06:56 PM. |
~Rest In Peace~
do yourself a favor get poly and i would get them with zert fittings
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by fastwillie 696969; 02-14-2007 at 06:53 PM. |
#7 | |
It's a 71 C20. I wasn't aware that the front end did not have bushings, I just assumed so. Guess that's why ECE didn't add bushings to the parts quote I asked for. So, the only bushings would be for the sway bar? Thanks for all the replies!! ![]()
#8 | |
C10 Club Tennessee
Not sure where you are located Greubin
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Napa offers everything except the springs. We sell Dana or TRW
I can get everything at LMC for $569 including springs and shocks
C10 Club Tennessee
That's high, of course LMC is high. Try using one of the vendors here on the board. I'm almost positive that they would beat that.
Junior Member
![]() Join Date: Jun 2003
I bought everything listed below from O-Reilleys, however it is for a C10 1972:
2 Moog K6147 control arm kit $111.98 2 Moog K6117T balljoint $53.98 2 Moog ES2004S adj sleeve $21.98 1 Moog K6131 pitman arm $68.99 2 ADC K6124 ball joint $63.98 2 Moog ES415RL tie rod end $47.98 2 Moog K6098 control arm kit $83.98 2 Moog ES403L tie rod end $41.98 Total with tax $524.55 You may find a cheaper kit, however these are all Moog components available locally - no shipping charges. These parts are heavy. PS - Autozone has some cheaper parts I believe they that some of the stuff was TRW. Good Luck |
#13 |
C10 Club Tennessee
O'Reilly also carries a lower brand called AutoDrive, which is made by TRW. At my store it is usually at least 35%-40% cheaper then MOOG.
#14 |
C10 Club Tennessee
For the AutoDrive Brand:
Upper Ball Joint-15.99x2 Lower Ball Joint-13.99x2 Upper Control Arm Kit:29.99x2 Lower Control Arm Kit:34.99x2 Pitman Arm:36.99 Outer Tie Rod End:11.99x2 Inner Tie Rod End:13.99x2 Adjusting Sleeve:6.99x2 Idler Arm:15.99 All of this costs less then $300 not including tax. AutoDrive uses the same part numbers as MOOG. This is what I bought for my blazer, of course I got my discount, which made it all about $200 SWEET!!
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 02-15-2007 at 10:14 AM. |
#15 | |
One piece of advise, BUY NEW SHAFTS as well as the old ones will be wear mated to the old bushing. The bushing are a soft material and if you reuse the shaft, you are going to wear out the bushing very fast and will find yourself doing this job again in the very near future.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
#16 |
All excellent info. I'll check with the local parts house.
#17 |
WTF, my local parts hourse quoted me $1087 for front end parts. Guess that must be San Francisco Bay Area prices..looks like I'll be ordering online. I'm going to check with NAPA next before going online.
#18 |
Chief Honcho In Charge
So is there a good FAQ on rebuilding a front end of a K10...
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
#19 |
I just did this myself on my '72. Ideally you use a press to handle the lower ball joint removal and installation. The giant "C" clamp thing/free tool rental was a bear to use even with a 450lb impact wrench. Remove the bushings from the control arms or at least loosen them after you take the springs out but while they're still on the truck. You'll need an air hammer and rivet cutter to replace the upper ball joins or a center punch and a careful/steady drill hand. At some point GM replaced the stock U bolts with heavier duty ones which are still stocked at the dealers. I purchased my whole front end rebuild kit from Early Classic. They're great to deal with.
Then I tackled the rear leaf springs...yow. ![]() |
