![]() Join Date: Jul 2006
For those with an adjustable and relocated panhard bar!!!
How much clearance do you have between the panhard bar and the diff cover?
I just bought a new diff cover that is cast aluminum and acts as a stud girdle but it hangs of the axle significatly more than the stock cover... I have the axle in the shop for the rebuild and the rest of the truck is buried under snow/ice so I have no way of measuring anyhting right now...
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
Next project: 1970 K10
Re: For those with an adjustable and relocated panhard bar!!!
I don't have my "air tape" handy, but this should give you an idea. That's 2.5" pipe, so... 1.25" to 1.5"??
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 02-14-2007 at 11:12 PM. |
Cool, thanks...that helps a lot...This is the diff cover I got. I was just worried that the edges of the girdle boss near the pre-load screws would interfere...
Too many projects
Mine taps itself when layed out and the frame on the axle (no notch), but that's a stock bar made adjustable in the stock location.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
I have the CPP "Deluxe" track bar and it's a little closer to the diff than stock. I have about an inch, but the bracket that mounts to the passenger trailing arm does have a little bit of adjustment. So I think I could slide it about 1/4" further away if I needed to.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
