Old 04-25-2002, 02:25 PM   #1
MikeB
MikeB's Avatar
Question How to do a frame-off?
A few questions: What's the best way to lift the cab and bed (long, wide) off the frame? Where do you then set the cab and bed to access underneath them? My 69 looks great from the outside, but I have lots of surface rust on the frame, under the floor pan, etc. And there's no way I can get to it all without pulling the cab and bed. Thanks for your advice.
MikeB
69 C-10 Fleetside, mild 383, Dart Iron Eagle 180cc heads, Crane Energizer 266 cam and 1.6 roller rockers, Edelbrock Performer manifold and 600cfm carb, HEI w/ MSD components, 1986 front spindles/disc brakes, Vintage Air in-dash, lowered 2"/3".
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-25-2002, 02:32 PM   #2
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
Post
Well if you have a sand blaster & dont mind wearing the sand you good do o.k. job of getting grime off the bottom, but if you rally want it to be nice it is worth taking the cab off to do it. To take the bed off is not that bad if you have 3-4 friends to help just put it on some sturdy saw horses. the cab you can set on a skid with some caster wheels so you can roll it around, makes it alot easier. Hope I helped.
Diggin 69
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
Eaton,Oh
rebelryder@hotmail.com
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
diggin69 is offline   Reply With Quote
Old 04-25-2002, 02:48 PM   #3
MikeB
MikeB's Avatar
Post
The bed's easy, but what's the best way to lift the cab. Can 4-6 guys lift it from the bottom? I have heard that you run a couple 4x4 pieces of lumber from the driver's side to passenger side and lift it by the roof. But that sounds like too much weight on the roof.
Mike
Old 04-25-2002, 02:56 PM   #4
69 longhorn
Post
I lifted & set the last cab with a picker through the window(rolled down first!). I pulled the seat,& set up chains fastened to the floor(off seat mounting holes), & had to drill a hole center of the trans hump,close to the firewall to bolt a chain to get "balance". 4 guys can lift the cab,but its a stumble walk across the rails. Good luck........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-25-2002, 03:24 PM   #5
Maximum Overdrive
December 21, 2012
Post
I have heard of people using the 4x4 method but they have everything stripped from the cab. Doors, windshield,etc etc.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 04-25-2002, 07:28 PM   #6
chevy71super
Post
My self and my son-in-law lifted my cab on and off the frame a couple of times. It was stripped, no doors or anything, except for the windshield.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 04-25-2002, 07:59 PM   #7
MikeB
MikeB's Avatar
Smile
Thanks for all the suggestions. Now all I need is that 24x30ft shop!
Mike
