02-15-2007, 10:04 AM | #1 |
Gen 3 6.0 Conversion
Im getting ready to start converting my 70 Suburban to a 6.0 Gen 3. Looking for suggestions on motor mounts, headers, stand alone wire harness, pictures from anybody that has done this already.
Thanks |
02-15-2007, 01:17 PM | #2 | |
Re: Gen 3 6.0 Conversion
Mike
Mike Redpath |
02-15-2007, 02:45 PM | #3 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-15-2007 at 02:45 PM. |
02-15-2007, 03:01 PM | #4 |
www.pacificfab.net mods harnesses and ecms. Phone number is on the site and Kevin is very knowledgable about the swaps.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " Last edited by jays68yak; 02-15-2007 at 03:01 PM. |
02-15-2007, 04:09 PM | #5 |
Junior Member
I have ECE motor mounts. My 5.3 sits nice with the ECE mounts. I do not have the wiring yet but I am planning on getting it from Speartech.
02-15-2007, 04:20 PM | #6 |
Questionable
See signature. 12-13 pages of writeup on a '01 LS1 5.7L, lots of items probably apply to yours.
Search feature is your friend. Good search term: GenIII ls1tech.com is full of people with hybrid trucks like mine, like what yours plans to be.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
02-16-2007, 04:00 PM | #7 |
Tried the GEN III search dosent ever come up with any results.
Shifty I see in your build thread you switced from a 6.0 to a 5.3 was there problems with the 6.0, and where did you get your headers. |
02-16-2007, 05:11 PM | #8 |
Questionable
Stop searching "Gen III" and start searching "GenIII". That space between "Gen" and "III" is the difference between 'no results' and 'lots of results'. The forum search feature ignores 3-letter search terms, so if you break it into two three-letter search terms, you're screwing yourself.
I just want to be clear here, I used a 5.7, not a 5.3 or 6.0, if you check my last post it's listed as a 5.7 as well . I wanted a T56 tranny, I did not want an auto tranny (although the install would have been HELLACIOUSLY easier), and wanted to buy a engine/tranny combo that was already mated together from the factory, so ... since I've never seen a 6spd truck, what I got is what I ended up with! The performance numbers for the WS6/LS1 drivetrain I bought were more what I was looking for, versus the truck engines. The 6.0 has better buildup potential for big HP, but that's not what I'm going for, so .... LS1 out of a TransAm WS6 it was ...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-16-2007 at 05:14 PM. |
02-16-2007, 07:36 PM | #9 |
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
02-19-2007, 08:03 PM | #10 |
Active Member
Does anyone make motor mounts for the 6.0L into 4x4 trucks? Looks like ECE only has them for 2wd
71 Blazer CST 72 K20 Capt USAF |
02-19-2007, 10:38 PM | #11 |
Junior Member
I can tell you from experience that the ones from ECE won't work on a 4x4. I used the ones from S&P and they worked fine.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
02-23-2007, 08:20 PM | #12 |
Active Member
Ok, I this may be a stupid question, but what is S&P?
02-23-2007, 08:45 PM | #13 |
speed and performance, they have alot of stuff for the gen3 conversions..
02-23-2007, 08:50 PM | #14 |
Active Member
02-23-2007, 08:52 PM | #15 |
Insert Title Here
Street and Performance
http://www.hotrodlane.cc/
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-10-2007, 11:57 PM | #16 |
Cereal Killer
which mounts i n particular did you use billyjo? he ones that bolt to the 4 6.0 motor mount holes and have the 3 bolt pattern ahead of the stock mounts? Reusing one of the block mounts? Did they get into the a/c comp?
If I dont do it....somebody else will. |
03-11-2007, 08:10 PM | #17 |
Junior Member
Those are the ones that I used and I was able to get the A/C compressor in although I haven't tried hooking it up yet. I've seen some pics of fitting that looks like it should work. I'll let you know when summer gets a little closer.
03-11-2007, 08:40 PM | #18 |
Cereal Killer
Billyjo....thanks for the info....i knocked a couple spots off the a/c bracket today and got it to fit..wish i could mock it up somehow before i pull my blazer apart.
07-16-2011, 11:22 PM | #19 |
Did you ever get any part #'s for the headers???
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
07-16-2011, 11:35 PM | #20 |
I would hope so. If he didn't find any for 4 years that would really suck...
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
07-16-2011, 11:39 PM | #21 |
Ha wow!!!!!!!!!!!1 I didn't even notice how old this thread was, I was just browsing around.... LMAO
07-16-2011, 11:59 PM | #22 |
LOL. Old but good.
07-17-2011, 12:18 AM | #23 |
He should be "done" with his project by now. Hmmm, lets see. He can't seem to finish any of his projects it appears. LOL.
