How do you bypass the neutral safety switch?
Just bought a 72 Suburban and the previous owner took out the tilt column and put a regular truck column in. The column is misaligned and the neutral safety switch is telling it not to start(I think???). I found the switch under the dash on the column. There are two plugs going into it. One has two green wires and the other has two purple wires. When the truck is in park the indicator on the column is actually to the left of where the "P" is. Just trying to figure out how to get this thing to start again. Battery has 12.6 volts. I also hear a relay clicking in the dash when I try to start it. I would even settle for how to hot wire the truck for now. Right now it's stuck in my driveway blocking the garage, so I can't even pull the GTO out and take that for a spin. Thanks in advance.
-Jon
1972 3-door K10 Sold and now looking for another one 2005 Pontiac GTO |
village idiot
Re: How do you bypass the neutral safety switch?
have you tried starting it in neutral?
pull the two wires off the neutral safety switch and connect them directly together
I tried starting it in neutral and nothing happens. I even moved it along every notch and tried starting it and nothing.
There are four wires there. Two on each connector. If you connect them to each other a certain way it blows the fuse.
TOTY 2006
![]() Join Date: Dec 1999
Pull the two purple wires and put them together. The other two wires are for your reverse lights....
Going out right now to try the two purple wires. Hope it starts. Fingers crossed.
It didn't start. I just get a click from something in the dash.
![]() I started a new thread for the new problem since the neutral safety switch bypass didn't work.
1972 3-door K10 Sold and now looking for another one 2005 Pontiac GTO Last edited by jon6.0; 02-15-2007 at 12:59 PM. |
