Old 02-15-2007, 01:22 PM   #1
skokie
skokie's Avatar
6 3/4 or 8 inch balancer
I have to swap out my 6 3/4 balancer and I was up at summit looking around and I saw some 8 inch balancers. Which one would be better to use on a stock 350?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-15-2007, 01:30 PM   #2
Kid
Kid's Avatar
Re: 6 3/4 or 8 inch balancer
The 8" balancer will perform its function better than a 6 3/4" can. (dampen the engine harmonics)
In this case, biger is better. It can be argured that it costs some HP, tho minimal.
Kid is offline   Reply With Quote
Old 02-15-2007, 01:41 PM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I would suggest the 8" on street driven engines for the better harmonic suppression.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-15-2007, 01:46 PM   #4
skokie
skokie's Avatar
Ok what about the pulleys? Will they bolt up to a 8?
68 build thread
Old 02-15-2007, 02:41 PM   #5
RACINJASON22
GEARHEAD
Yes the center hub and pulley bolt pattern is the same on both.
Old 02-15-2007, 08:51 PM   #6
cooters
just make sure to change timing mark tab
cooters is offline   Reply With Quote
Old 02-15-2007, 11:41 PM   #7
BCOWANWHEELS
whatever came off is what i,d put back on . and i,d use a GM brand back on it if possible.
BCOWANWHEELS is offline   Reply With Quote
Old 02-16-2007, 12:18 AM   #8
cooters
i use PIONEER brand balancers, good bang for the buck
Old 02-16-2007, 07:27 PM   #9
skokie
skokie's Avatar
I picked up a 8 inch the other day. I took off the 6 3/4 last night and the rubber was falling out of it. I got a new tab for it to. I will install it here in the next day or so. The truck is sitting in the driveway and I got a bunch more to do to it before it hits the road again
68 build thread
Old 02-16-2007, 09:16 PM   #10
cooters
make sure you use an install tool (not a hammer)
Old 02-16-2007, 09:26 PM   #11
WorkinLonghorn
WorkinLonghorn's Avatar
The last time I did this I think I just torqued the mounting bolt and it went right on,but then my memory ain't what it used to be.Maybe I rapped the inner hub with a mallet.Did I screw up? TDC seems to be way off 10,000 miles later.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 02-16-2007, 09:29 PM   #12
BCOWANWHEELS
most 8" balancer came from 4 bolt main engines and steel cranks
Old 02-16-2007, 09:33 PM   #13
rage'nrat638
rage'nrat638's Avatar
THIS IS THE TOOL for installing
rage'nrat638 is offline   Reply With Quote
Old 02-16-2007, 09:48 PM   #14
Stroker
skokie, It depends on the year of your truck and what options you have. On my 68 which was originally a 327 I had some interference with the power steering pump when I switched to a 8". I ended up having to switch to a later model power steering bracket to have enough clearance. If you don't have PS or already have the later model bracket the 8" should be fine and probably does a better job.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 02-16-2007, 10:47 PM   #15
cameeks
Long Fleet Club
cameeks's Avatar
(Not recommended)
Back when I started working on engines my first balancer install I taped it on untile i could get some threads started then impacted it the rest of the way. For the rest of the time I had that engine I had to soak the balancer bolt in red lock tight then install it becouse the impact stripped out the snout on the crank.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 02-17-2007, 12:58 AM   #16
skokie
skokie's Avatar
I do have a installer tool that looks similar to what regenrat has there. I hope I dont run into the interference issue with the power steering. I may have to do a test fit to make sure.
68 build thread
Old 02-17-2007, 11:31 PM   #17
cooters
the other problem with the hammer install is beating up the thrust bearing in the crankshaft
