Old 02-15-2007, 03:28 PM   #1
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Quick ratio vs Variable ratio
Looking to hear some experinces/opionions regarding Quick ratio vs Variable ratio steering gears.
I do know that the variable gear may have a "softer" feel on the highway. It also has less turns lock to lock (quick - 3.5, variable - 3.25).
What do you have, do you like it and why?
Thanks,
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 02-15-2007, 05:44 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Quick ratio vs Variable ratio
I have variable ratio on my longhorn, & I do like it . Its a he!! of a bunch better than what came off the old 69......plus it was cheap! It came off an 84 burb that was free for the tow away the most noticeable diff is in town, a lot less swingin on the wheel to do the corners. I dont think it feel bad on the hyway either. I havent driven a close ratio box on these trucks to compair with tho.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
