Old 04-19-2002, 08:02 PM   #1
gabet40
Post differences in 1 or 2 pc driveshaft?
my one piece driveline has broke twice from rubbing on the carrier bearing housing, the first time cracking the case on my turbo 400, and this time the case on my brand new 700r4. so i think im switchin back to the 2-piece and am wondering what kind of changes to expect. thanx in advance
69 1/2 ton, 350ci/th400, change from long/fleet to short/fleet, shaved door handles, custom sounds, dual headman blockhuggers/flowmasters exhaust, shaved tailgate, 18" budniks with matching steering wheel, 4/6 drop, power windows
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 04-19-2002, 08:06 PM   #2
Desert Rat
Desert Rat's Avatar
Post
should be able to bolt it right in as long as the carrier bearing support bracket is there.Whys your driveline rubbing?I have 1 pc in mine no problems.something dont sound right
Desert Rat is offline   Reply With Quote
Old 04-19-2002, 08:30 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Mine came with a one piece shaft...defenatly no problems here.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-19-2002, 08:39 PM   #4
gabet40
Post
well i think it might be because i lowered my truck, but im not sure, i know the first one was a little unbalanced and very wide but this one was two months old and much narrower and had plenty of clearance. two weeks ago there wasnt a single sign of any metal to metal on the driveshaft. so it seems like it was sudden
Former owner of:
Old 04-19-2002, 09:47 PM   #5
LT-102
Post
I've thought about changing to a 1 piece shaft (I have a 71'C20) and I was under the truck tonight and trying to figure out if the single shaft would hit against where the carrier bearing housing currently is on a bumpy roadway. The carrier bearing seems to be the weak link in my drivetrain. Also, what is a good donor vehicle for a single shaft.
LT-102 is offline   Reply With Quote
Old 04-20-2002, 05:09 AM   #6
Andy4639
Old member
Andy4639's Avatar
Cool
I don't understand all the problems with the two piece drive shafts on these trucks that I keep hearing about. I have one and lowered 2" in front 3" in back. Installed 700-R4, cut almost 1" out of drive shaft front half for the difference in transmissions, moved the trans. crossmember back, had all of the universal's replaced and keep them greased, and had it balanced, and have got over 150,000 miles out of it. I have never had a bit of trouble with it.
Andy
71's Are for ever!!! or 67,68,69,70,72
71,factory tach,tilt for straight drive,gauges,ac,305 HO TPI with 700-R4 lowered,17" wheels
www.geocities.com/chevy71tpi/main.html]
www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-20-2002, 05:25 AM   #7
gabet40
Post
yeah i heard that the two piece takes a little torque away, or was it the one piece? i forgot. i guess theres also a little less vibration with a two piece. any input on the pros and cons between the two?
Former owner of:
Old 04-20-2002, 06:34 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Arrow
My '69 short stepside has a one piece driveshaft but I have no idea what it was from as it was in it when I bought it.
I had to notch out the carrier bearing mount area quite a bit myself. When I would try to haul anything, I could hear the driveshaft hitting.
63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle
Parts for sale:
http://www.angelfire.com/trek/mr409/items4sale.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-20-2002, 08:17 PM   #9
DarkFox1
in WAY over my head
DarkFox1's Avatar
Post
wow, glad I found this. My donor frame is missing the 2 peice carrier. Its from a '69 or 70, I do beleive the rearend #s said '69. At any rate.. it was a 6 cyl with a manual and a 3.73 open rear, could it be that the carrier was removed with the driveshaft (considering this truck was a parts truck and had been pretty much raped of everything BUT the frame) or did they come this way at all?
I'm doing a 2/4 drop on mine. haven't gotten anything in it as far as drivetrain yet... but if its gonna be a problem I may hafta switch to 2 peice I dont want to, from my understanding you can lose about 10ft lbs of torque via that 2nd universal.. not sure tho.
Projects
Belair '71 C10 LWB to SWB conversion:C10 project page
65Chevelle pics coming soon
DarkFox1 is offline   Reply With Quote
Old 04-20-2002, 08:20 PM   #10
Longhorn Man
Post
You could get swb trucks with a one piece shaft. I have seen 2. Mine, and an all original '67 inline/4 speed farm truck. It was a short step Chevy. (both of them coil susp)
[This message has been edited by longhornmail (edited April 20, 2002).]
Old 04-20-2002, 08:32 PM   #11
DarkFox1
in WAY over my head
DarkFox1's Avatar
Post
was this a rarity? this truck was too a farm truck, heh, I can see the battle damage.. YOU DONT PULL UP TREES WITH CROSSMEMBERS! lol I had to replace my back crossmember cos it appeared to have been yanked by a chain or rope. Along with the unusual.. mulch deposits under a few choice frame components (mainly the rear spring pads that are rivetted to the frame) I'm 100% it was a farm truck :P
Well, you know.. the 1 peices were inteded for stock ride heigh.. it very well could be the drop thats causing the problme. You dont think you could make perhaps some sort of home-made bushing kinda thing that fits in the crossmember's opening?
Projects
Old 04-20-2002, 10:05 PM   #12
Longhorn Man
Post
Even loaded, you shuldn't have any trouble...They were intended to be way overloaded, so the shaft should still clear.
Old 04-24-2002, 11:33 AM   #13
gabet40
Post
yeah i dont think i should have any problems either, but i do. i dont know, maybe my rearend is going out and put some kind of weird pull on the shaft causing it to start twerking. who knows. but i was cruising at about 67-72 mph (about 2200 rpms) and had been for about ten minutes when it happened.
but i dont think im going to take another chance on it so ill probably just switch to two piece. the local parts store stocks the carrier and im just going to look for a two piece at a wrecking yard or off of here for my driveshaft guy to modify. i picked up my new 700 core for $100. the tranny shop said they can just switch all the parts from the two month old one to the new one. at an addition all charge of course.
Former owner of:
Old 04-24-2002, 01:55 PM   #14
bad 71 chevy
bad 71 chevy's Avatar
Post
i have a 2 pice and i am blowing the carrer berring out what do i do to change to a 1 pice the drive shaft place will not mess with mine because they say it is to long but i saw a lot of you guys have a 1 pice with a longbed how did you do it tell me please
also what kind of doner truck has the 1 peice drive shaft that can be alterd at a drivelin place?
I NEED HELP ASAP
71 Chevy C/10 lwb 350 300 hp
3 speed
3.73 rear end
Edelbrock perfomer rpm manifold
Edelbrock 650 cfm carb
edelbrock alumacoat headers
71 c/20 project truck
E-mail t1983@hotmail.com
[This message has been edited by bad 71 chevy (edited April 24, 2002).]
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 04-24-2002, 02:23 PM   #15
69 longhorn
Post
I was told by a local driveline shop,that they can do a 73" shaft,if it is at least 4" dia tube,but they said they really didnt like making them that long,as they tend to whip,& will eventually fail. My longhorn has the good 2pc setup(slip yolk in the middle),& the owner of the shop told me I would be better off to leave it like that.....guess he didnt need my money bad enough to "steal" it!.........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-24-2002, 03:18 PM   #16
Alexis
Member since 2000
Alexis's Avatar
Post
my blazer had a 1 piece stock, and i had no problems.
Mechanic @ California Concept
Britney: 1970 2wd K/5 Blazer (Frame up)
Jessica: 1967 2wd SWB (pops daily driver)
Helga: 1972 4x4 3/4ton LWB (my daily driver)
AIM:Alexmart1
Mountain View, Cali
Alexis is offline   Reply With Quote
Old 04-24-2002, 03:41 PM   #17
oldred
Post
I put a 1 piece 4" dia. drive shaft in my '67 Shortbox, which is lowered 4" in the back. I've never had any rubbing problems. In fact, it looks like it was made to be this way.
1967 Chevy shortbox
oldred is offline   Reply With Quote
Old 04-24-2002, 06:05 PM   #18
bad 71 chevy
Post
my drive shaft is 47 1/4" what is another truck that came stock with a longer one pice drive shaft the drive line place said they can shorten or lengthen a stock one pice one but they cant make me one longer that 43" out of aluminum but i need a 1 pice because i am tired of replacing carrir berings i have replaced 5 in the last year and a half and i am tired of it.
thanks for helping
3 speed
3.73 rear end
5 speed nv3500
3.73 rear end
Headmen headers
Old 04-24-2002, 08:03 PM   #19
slam33
slam33's Avatar
Post
The problem with the carrier bearings is improper alignment, the rubber cushion getting pushed to one side. Either by not getting it staight, (it can be twisted just a bit) or if the motor or trans mounts are sagging or the motor/trans is not straight in line. U-joints need to be in good shape too.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 04-25-2002, 08:12 PM   #20
gabet40
Post
if i knew why mine was rubbing id fix it and stick with the one piece, but im not going to keep crackin tranny cases just to figure out why. im goin back to the two piece.
Former owner of:
Old 04-25-2002, 08:20 PM   #21
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
I've had a one-piece ever since I had a TH400 put in over two years / nearly 20,000 miles ago, and zero rubbing problems. I don't know if the guy who installed it hogged out the crossmember, though. Lowered 2.5" front, 4" rear.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-25-2002, 08:31 PM   #22
Longhorn Man
Post
If you are going through C-bearings, check to see that your tranny and engine are mounted straight, then get your surrent 2 pc shaft ballanced and ensure it is straight. That is about all I can see that would cause this kind of trouble.
