Old 02-16-2007, 12:09 AM   #1
manimal
manimal's Avatar
HYDROBOOST question
Do you have to run power steering with a hydroboost,or can you just use the pump WITHOUT the gear box? Thanks
-Lance
manimal is offline   Reply With Quote
Old 02-16-2007, 09:21 AM   #2
AKChevyman
Chevy Forever
AKChevyman's Avatar
Re: HYDROBOOST question
I can't see why you would have to use it excpet that the hydroboost is designed to let high pressue pass through it to go to the steering box. I guess you could block that line off and just use the high pressure inlet and low pressure outlet lines. Maybe someone with more experince will chime in.
My first love
1971 C20
Hugger orange
Getting face lift and heart transplant .30 402 BB /TH400 and GV
Wifes car
1969 Chevelle SS 396 325hp/TH400
Factroy A/C Automatic w/ Floor shift console.
restored.
AKChevyman is offline   Reply With Quote
Old 02-16-2007, 11:26 AM   #3
BUDDY
Global warming is a myth
BUDDY's Avatar
Arrow Re: HYDROBOOST question
It makes sense that you could bypass the steering gear box & just run the pump to the hydro-boost unit, but I can't see why you'd want to.
It looks like you have a 4x4 with bigger than stock tires. I'd imagine you'd be kicking yourself for getting rid of the PS part of that equation. I used to have a little Aspire, (econo DD), with no PS & that thing was a pain to turn when I wasn't moving or in parking lots, & it only had 13" pizza cutter tires. I can't imagine trying to turn a lifted 4x4 with larger than stock tires w/o PS. You'd give you're arms quite a workout, but if that's what you're going for, go for it!!
Later,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 02-16-2007, 11:58 AM   #4
manimal
manimal's Avatar
I was thinking of it for my 69 c10 2wd.
Old 02-16-2007, 12:42 PM   #5
unreconstructed1
nec absolutum
unreconstructed1's Avatar
i'll tell you one thing, my 67 has manual steering/ manual brakes. I love my truck to death, but getting out of tight spots from a dead stop is a fairly fun experience. I'll be the first one to tell you to do your own thing, but once you aint got it, you learn real quick that power steering really is a convenience after all.
unreconstructed1 is offline   Reply With Quote
Old 02-16-2007, 01:33 PM   #6
manimal
manimal's Avatar
I dont have power steering. I too have manual EVERYTHING. But with a narrower tire in the front the manual steering is great! Besides that,my steering box is fairly new as is all the front suspension. Maybe I will put p/s on if I have the pump hangin there anyways.
-Lance
