Junior Member
![]() Join Date: Jan 2007
A Gauge Cluster Question....
I am wondering if any1 knows what has to be done to replace my stock cluster (speedo, fuel, and generator) with a full cluster that has fuel, tach, amp, vacuum, oil pressure and temp. How about the harness? Tach? Temp and oil pressure switches? Thanks.
68 LongStep 350/ 3 Spd (ongoing project) 04 Suburban Z71 (daily driver) 97 C5 Corvette ( sold when 2nd baby came) 90 454SS pick up (sold) 1970 Chevelle Malibu 454 For Sale $8,000. my art website http://www.louietrangallery.com/ my 68 Longstep...No Shortstep Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=296736 |
Re: A Gauge Cluster Question....
there is a link on paul,s gmc page(i think?) maybe someone can confirm this,
on the website it shows how to convert your stock harness to work with, a gauge setup. |
#3 | |||
Union Electrician
Yep he sure does, here is the link to what needs to be done > http://www.gmcpauls.com/Tech%20Tips1.htm
Go down the page a little and you will see it. You would need a different temp sending unit, a hard line(maybe some fittings) for oil pressure and vacuum pressure, you will also need the tach wiring harness which is very easy to install(about 15 minutes). The wiring swap depending on your knowledge of these trucks should take the better part of a day to a full weekend, like I said depending on you. You have some wire and fuses,(misc connectors) sending units and stuff, so a part run or two will be in the cards for sure. Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Junior Member
Thanks guys....I'll check it out. Hopefully I can do it...LOL
