Old 02-16-2007, 02:42 PM   #1
Midlothian Electric
Midlothian Electric's Avatar
What is this? and why is it running my battery down?
Everytime I connect the battery, the device circled clicks. It's on the driver's side firewall
Quenton Lee
Midlothian Electric Comapny Inc.
Electrical Contractors Since 1965
Midlothian Electric is offline   Reply With Quote
Old 02-16-2007, 02:56 PM   #2
john
member #16
john's Avatar
Re: What is this? and why is it running my battery down?
Looks like a TCS relay. Most people throw all of that system away.
john is offline   Reply With Quote
Old 02-16-2007, 02:59 PM   #3
ibad57
ibad57's Avatar
it could be horn relay unless horn is working properly
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 02-16-2007, 03:30 PM   #4
kbs71
71 rustless in texas
kbs71's Avatar
It's not the horn relay there ain't no red wires going to it.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 02-16-2007, 05:46 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just unplug them.
Old 02-16-2007, 06:36 PM   #6
hvychve
To The Levy
hvychve's Avatar
I am gonna make a stab at this one, I had another guy with the same question about a year ago.
The Horn Relay wire colors are going to be Black, Red and Dark Green.....
I have included a few photos of what I think this other relay is, I have colors for one of the relays but not the other, never the less, you may be able to figure which one it might be.
Check your wire colors and see if these are on it: Pink, Orange, and Two Dark green wires.... if these four wires are there and match , this is an Anti-Dieseling relay....I think
On Automatic equiped Vehicles that had A/c. what it does is actually turns on the A/c compressor clutch for about three seconds after keys is switched off, this allows extra load on the engine to keep from dieseling....
There is another photo of a relay that is sorta in the same purpose, it plays a roll with manual transmission models, operates a few function of the vacuum advance. The dist. vac. adv. has been eliminated in the low forward gears ,the control of the vacuum advance is accomplished by means of a solenoid vac. sw. which is energized by grounding a switch at the trans.thus , two seperate throttle settings are now possible-one for curb idel and one for deceleration hydrocarbon control.(emissions). This type of system is incorperated for a couple reasons , lower emissions at lower obrainable idle speeds and for dieseling purposes. if the idle is allowed to be lower , this in turns allows for the lack of dieseling....so to put it mildly, These may be removed, hopefuly the wire colors might match, I seriuosly doubt tht this had the solenoid mounted on the throttle, but It may have...
components involved would be : Time-Delay Relay, Reversing Relay, Note that in the diagram, it has switched power from ign. sw. to both relays, So it should not have power unless key in accessory, which dont make sence to me, however, maybe some of this may help.....
hvychve is offline   Reply With Quote
Old 02-16-2007, 06:39 PM   #7
72k20+afew
don't know what it is but i just threw one out maybe i could dig it outa the garbage for ya the truck still runs must not be important
No NO NO Sir Don't Want em Can't Use em Couldn't Afford em If I Did
72k20+afew is offline   Reply With Quote
Old 02-16-2007, 07:34 PM   #8
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
A lot of neat guesses, but it looks like the TCS, or Transmission Controlled Spark system relay. This was a gimicky first-gen emmisions control device that only allowed distributer vacuum advance in high gear when the engine was warmed up. Like LonghornMan says, just unplug the wires. You'll probably find a {leaking} vacuum valve in there somewhere too. Just remove it and route your vacuum advance hose directly to the port on the carb like nature had intended.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-16-2007, 07:54 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I agree with everybody that it's a tcs relay. That doesn't explain why it clicks when you hook up the battery unless there is a switch stuck somewhere.
Unplugging the relay should fix the current draw though so you won't run the battery down.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-17-2007, 01:29 AM   #10
hvychve
To The Levy
hvychve's Avatar
vettevet, I can tell you dont know, you must be new
