Old 02-16-2007, 04:54 PM   #1
Zonaman
Zonaman's Avatar
Rear Tie Rod symptoms?
Aside from the obvious (cracked, rotting rubber), what would be the warning signs indicating that your rear tie rod (panhard bar) bushings are shot? In other words, would you hear or feel anything from down there?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 02-16-2007, 05:50 PM   #2
john
member #16
john's Avatar
Re: Rear Tie Rod symptoms?
If the rubber is shot it will usually give out a clunk noise.
john is offline   Reply With Quote
Old 02-16-2007, 06:02 PM   #3
67cruiser
67cruiser's Avatar
If you grab the bed of your truck and push side to side you will hear that clunking sound. That's what mine did anyway. When I got the bar off the bushing on the rear end was completely gone. I called around looking for the bushing at all auto part stores and none of them stocked nor could they even get them, ended up having to buy them from Classic Chevy here in OKC.
67 C10 SWB
350-Turbo 400 tranny-Disc brake
"Those who live by the sword get shot by those who don't"
67cruiser is offline   Reply With Quote
