Old 08-28-2002, 10:43 PM   #1
colohusker
Question TH400 Yoke ?
A friend has a TH400 with a bolt on yoke, but needs to convert to a slip on yoke, and he was wondering what are the steps to do it? Is it just unbolting the yoke, and then slipping the other yoke on?
Thanks,
Scott
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 08-28-2002, 11:08 PM   #2
Jeff M.
Jeff M.'s Avatar
You got it. Just take the bolt out and tap the yoke off. The 400 slip yolk will slide right on.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 08-28-2002, 11:59 PM   #3
colohusker
Thanks Jeff! Do you know if there is a length difference between the 2 requiring any changes to the driveshaft length?
Longmont, CO
Old 08-29-2002, 08:20 AM   #4
Jeff M.
Jeff M.'s Avatar
Hmmm. Really don't know. You're talking about the drive shaft I assume. I'm kinna thinking the slip yoke type may be a bit longer. The u-joint flange on the bolt on yoke goes from the trans to the drive shaft in a pretty short distance. Not a major problem because shortening the drive shaft is not too expensive and a lot of machine shops can do that. But honestly, I really don't know without having the yokes in front of me.
