putting 1 ton truckwheels under a C10
i have this 1986 C10 2 wheel drive that i want to put truckwheels under , not to realy up the loading capacity but more to make it look different.
im thinking on getting dropped spindles for a C30 and build those up with the C30 brakes and hubs . does anyone know if i can mount the spindles on the C10 A arms if so wat parts need to be adapted and if not how mush of the frontsuspention do i need to chainge
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
Re: putting 1 ton truckwheels under a C10
anyone?
Wide n'Low
![]() Join Date: Jan 2007
I just cam across a site that sells adapters to go from 8 to 10 lug wheels, but not 5 to ten.
As for parts needed to swap, take a look through the LMC website and compare the part numbers for the different pieces like the spindle, a-arms etc... You most likely could swap in a complete loaded spindle with caliper, rotor and all. I would check just to be sure. |
ok thanks ..... i was wondering if the balljoints that mount the spindle on the a arms would fit the C30 spindle
Active Member
try duallyscene.com that would be the best for your ?
thank you so much
Happy to be here
![]() Join Date: Mar 2000
The ball joints and tie rod ends aren't the same so you will have to change them. The C-10 A-arms are the same but the hole for the ball joint is smaller ( I think). You will have to change the A-arm or mod the hole to fit.
now this is info i can use , i was wondering how far i needed to switch stuff around .
from the looks of i i might be better off with C30 upper and lower arms and fit lowered C30 spindles they WILL fit on the C10 crossmember . i allso planned to get a complete delalum fiber bushingkit ...... i need to search a bit to see if there the same as for a C10 , logic tells me chevrolet makes them bigger for heavier capacity vehicles
