Old 02-17-2007, 11:30 AM   #1
68Stepbed
68Stepbed's Avatar
Where's your tach?
I have an AutoGuage 3 3/8" tach that I would like to put in my 86, but I can't figure out where to put it. I don't want to put it on top of the dash. The only place I can see it might work would be on the column in front of the shifter. Any ideas?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-17-2007, 11:36 AM   #2
Nolowrider
Nolowrider's Avatar
Re: Where's your tach?
That is where I have mine. Don't really like it there, but like you said there is not another place. Don't want to put holes on the dash pad.
Nolowrider is offline   Reply With Quote
Old 02-17-2007, 12:19 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Mine is right here.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-17-2007, 12:23 PM   #4
boatpuller
boatpuller's Avatar
Originally Posted by swervin ervin View Post
Mine is right here.
sweet dash
boatpuller is offline   Reply With Quote
Old 02-17-2007, 01:35 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
Mine is right here.
Hey swervin nice ! Is that a factory tach cluster and what's the scoop on the shift indicator lights ?
I'm not familiar with the later trucks since mine is a 74.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-17-2007, 02:06 PM   #6
82c10
needin' money
on the dash, at the bend
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 02-17-2007, 03:16 PM   #7
f.monroe
f.monroe's Avatar
Depends on what you are using the tach for . Mine are factory in the dash on my 77 and my 78 . If you are just using it for reference mount it on the bottom of the dash looking up or near the roof on the driver a pillar . If you need to see it for shifting , mount it where you dont have to take your eyes off the road too bad . I seen one that the owner built a bracket that uses the sun visor mounting point . It wa cool and no extra holes were required . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-17-2007, 03:23 PM   #8
HotRod73
HotRod73's Avatar
Mine is mounted on the dash and my shift light is mounted around the steering column on the 87 short wide.
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 02-17-2007, 05:30 PM   #9
stepside454
stepside454's Avatar
Mine is on the dash, dash pad wasnt perfect anyway
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 02-17-2007, 06:51 PM   #10
84 400
Sb 400 club
84 400's Avatar
I have not mounted mine yet but was thinking i will go were the red scribble is. Mine is a Sun pro II 3 inch. I tried mounting it on the colum but with having a tilt and auto it was just too much of a pain. To me down below is uslesss. True i don't really need it but thik it would be nice to have. IS there another way of mounting it with out drilling my dash? Also i have heard of the piller idea but still don't get it . anyways thanks
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 02-17-2007, 09:02 PM   #11
swervin ervin
No it's not a factory tach cluster.
http://www.73-87.com/7387garage/inte...s_recessed.htm
The article is from long ago. I have updated things since I wrote it. The shift indicator lights were moved from top center. They are so I can have a high beam, park brake and choke indicator lights. I added the shift light and the two gauges where the radio was, plus the billet bezel.
Mike
Old 02-17-2007, 10:11 PM   #12
84 400
Sb 400 club
84 400's Avatar
mike it looks really *****en. nice job
1985 C10 LWB Sold
Old 02-17-2007, 10:34 PM   #13
84slopwaggin
84slopwaggin's Avatar
Nice Erv but is the choke light really needed.
84slopwaggin is offline   Reply With Quote
Old 02-17-2007, 11:39 PM   #14
piecesparts
Parts and more parts
piecesparts's Avatar
I mounted mine and the son's on the left front pillar, just above the dash. (No Holes in the dash and I used the factory screw hole), so it could be removed and look clean. The tach is mounted to a piece of aluminum strapping that is tapered to follow the windshield rubber to hold it in place. It works well and the tach is right below eye level and easy to see.
piecesparts is offline   Reply With Quote
Old 02-18-2007, 02:16 AM   #15
84 400
Sb 400 club
84 400's Avatar
Peiceparts, you have mentioned this before and i think this is the way i am going to do mine. could you provide a picture of the setup or maybe a drawing? Also what tach are you running? I would really like to do the autometers but don't have the money right now. And i have a tach waiting to be hooked up.
thanks
1985 C10 LWB Sold
Old 02-18-2007, 03:55 AM   #16
84slopwaggin
Heres the old thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=221937
Old 02-18-2007, 09:11 AM   #17
Ziptar
Diesel Addict
Ziptar's Avatar
Mine is in the factory Cluster, sitting on my work bench
1979 C-10 Silverado w/ Olds 5.7L Diesel
Ziptar is offline   Reply With Quote
Old 02-18-2007, 11:11 AM   #18
piecesparts
84 400 if you look at the attached thread that 84sloppwaggin attached: Is there any more that you would need from those pictures?
Old 02-19-2007, 09:23 AM   #19
808486CHEVY
808486CHEVY's Avatar
I put mine on shifter column but i put it so that when shifter is in drive the tach is positioned on top Ill have to try to get a pic but dont have one right now
808486CHEVY is offline   Reply With Quote
Old 02-19-2007, 12:32 PM   #20
84 400
Sb 400 club
84 400's Avatar
Does that bracket tuck around or just stop at the window bolding? does it only have the one screew??
thanks
1985 C10 LWB Sold
Old 02-19-2007, 05:20 PM   #21
75Chevy90Kawi
the green machine
75Chevy90Kawi's Avatar
just for reference
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more...
2003 Suzuki TL1000R
1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more...
My pictures
75Chevy90Kawi is offline   Reply With Quote
