New Member
rear 8 inch drop and notch
i was just wondering,i dropped my truck 8 inches in the rear and it has coil springs and the rearend is right at an inch from the frame,do you guys think a bolt in small notch will be enough or will it hit the frame alot,i just dont want to cut the bed,thanks for any help guys.
Re: rear 8 inch drop and notch
Typical suspension movement is about 4": 2-up; 2-down. A bolt-in c-notch would work if you don't carry much of a load.
How did you arrive @ the 8" drop?
New Member
used 6 inch springs from early classics and 2 inch blocks from classic performance and pinion shims from them also and just need a notch.
I have a similar set-up right now, just home-made blocks instead of manufactured ones. I installed the bolt-in c-notch and I don't believe it has ever bottomed out (of course, luggage and my dogs are the heaviest things my truck carries.)
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
