02-18-2007, 02:54 PM | #1 |
installing radio in dash
hey everyone i am thinking about cutting the stock radio opening on my 72 to fit a cd player but b4 i do this i was wondering what you all use to secure the radio so it dosent move around. i know many of you will be against cutting it but if you have any ideas or suggestions post them.
thank you for any help |
02-18-2007, 03:41 PM | #2 |
its all about the +6 inches
Re: installing radio in dash
CUT IT UP!!!
I have mine cut up, and I just use the little cage that it slides into. Never had a problem. Been like that on 2 trucks, with 3 stereos now. |
02-18-2007, 03:47 PM | #3 |
should be enough, if you want more support then get a piece of metal strapping (lowes heat duct section) and bolt it to the back to hang the rear of the unit on. Bolt the other end to the firewall/dash and your set.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-18-2007, 04:14 PM | #4 |
wow i didnt even think of using the cage that it came with but i think i kno wht u mean. i guess some times i juss dont think of thew simple thing
thanks for the help |
02-18-2007, 04:51 PM | #5 |
Keep On Keepin' On
How about mounting it towards the bottom..
02-18-2007, 06:19 PM | #6 |
Yes look in the directions and it will show how you use the cage to lock it all in place. This is what I just did on project "LFD's Low buck truck build" and it worked out great. I also am against cutting the dash but their are not to many radios out their anymore that will work that are priced in the normal budget.
Kevin LFD Inc. |
02-18-2007, 11:36 PM | #7 |
Ya, those units are light weight enough that the "cage" is all you really need. Take a minute and look at the way the radio locks into the cage before you install it. If you need to slide it back out, it's nice to understand the workings of it.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
02-19-2007, 12:00 AM | #8 |
yea the cage will work... but you may want to use the metal strap as msgross stated . that strap was the only thing that saved my stero in my last truck. someone tried to steal it and they didnt have enough sense or was in a hurry to reach under the dash and unscrew it.. so the lil extra effort of the metal strap may save ya tunes.plus it keeps it from bouncy around too
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
02-19-2007, 12:07 AM | #9 |
well i'm against cuttin up a beautful dash so i bought a mount that goes underneath the dash without screwing anything up
02-19-2007, 12:08 AM | #10 |
Don't cut the dash!! Mount the radio under the dash or build a box and mount it on the hump. Cosmetic surgery on the dash isn't necessarily the best answer
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
02-19-2007, 01:03 AM | #11 |
I've see lots of places that sell radios with cd controls that fit the standard mounting.ie. JC Whitney,Brothers,Truck-Shop etc.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
02-19-2007, 02:24 AM | #12 |
Chief Honcho In Charge
What si so holy about the dash staying stock...I would imagine with a nice die grinder a very nice square hols could be made...as long as you do not grind into the curved part of that surround...the structural integrity of the dash does not change...
If there was some good stuff on the market...I say keep the dash....But I want the new technology with something to connect my ipod too. The whole two shaft thing is OK...but not sacred to me. I have scome to the resolutiuon to cut mine when I am at that point.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
02-19-2007, 03:34 AM | #13 |
Junior Member
Cut it. One less original...
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
02-19-2007, 04:37 AM | #14 |
This is one topic where people have very strong feelings one way or another....
I'd say, unless somebody in your area feels so strongly, that they are willing to do all the work to swap their cut dash for yours, and make sure it's painted to your liking, then what does it matter what anybody else thinks... My only advice: If you are going to cut it, take your time and do it right. as you are I inherited a horribly disfigured dash, not as bad as some i have seen on this board, but still, it's more work for me to fix than it would've taken to cut correctly the first time.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
02-19-2007, 09:34 AM | #15 |
I cut mine with a Dremel. I know there's a ton of naysayers on this one, but hey, everyone is different and I wanted a CD player in the dash.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
02-19-2007, 10:07 AM | #16 |
Dave's not here, man
I cut my dash and have the deck installed using the cage and MSGROSS' suggestion. I have the strap run to the bracket that the factory push button was bolted to and it's very secure.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 02-19-2007 at 10:09 AM. |
02-19-2007, 08:33 PM | #17 |
02-19-2007, 09:17 PM | #18 |
in the top left of the pic you can see mine i will take some better pics for you tomorrow if you would like
Redneck Rampage 1972 Chevrolet C-10 LWB 350 1972 Chevrolet K-20 LWB 502 LiFtEd |
02-19-2007, 09:30 PM | #19 |
Rolled on Paint Club
I cut mine and used the cage, and also put some 1" thick foam padding under and on top of the unit to stop it from bouncing.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
02-19-2007, 09:31 PM | #20 |
thats how mine is cept i made the hole so tight using the cage its not goin anywhere
02-19-2007, 09:35 PM | #21 |
Keep On Keepin' On
Just my preference...Something doesnt look right when putting a new CD player in the metal dash in our trucks..Doesnt look like it belongs...I will have a stock radio but mount aftermarket at the bottom of the dash..I did this on a 68 Coronet I had in college...
02-19-2007, 09:41 PM | #22 |
yeah i like the factory look i plan on getting the billit plate the make and putting it inthere then putting a factory bacn in it and i have my iPod witht the FM transmitter so i will just leave it on the one station lol
02-19-2007, 09:56 PM | #23 |
72 chevy
Just cut the top and bottem of each one and bend the ears back then you have somthing to bolt the cage to makes it solid.
02-19-2007, 11:27 PM | #24 |
Junior Member
I'll admit... When I was in high school, I did eventually cut the dash of my low mile Impala coupe to install a DIN chassis Alpine cassete player. Although, only after I had a nice dash in reserve. Cutting the steel dash of these trucks is a commitment.
02-20-2007, 12:53 AM | #25 |
Eat My Rust
Mine came with cut dash, atleast it was a clean cut. I cant say the same for the wiring...
