02-18-2007, 03:47 PM | #1 |
Weekend Warrior
Need some Help (no lights): not '67-'72 but you guys know alot
I have a car that has no lights. All the fuses are good. My wife said that last night she was driving and flashed the high beams @ someone cause they had thiers on. As soon as she did that she lost the lowbeams (she thought all other lights were working ok). She put the highbeams on and drove to her parents house and stayed there for the night (I was out of town). She drove home today in the daylight. I just went out to check it out - I turned the lights on and they Worked - flipped the Highbeams on and they shut off EVERYTHING! Tail, Markers, etc. Blinkers work, flashers work. The Highbeam light on the dash comes on if you hit the switch to the "momentary position" but when you flip it to the "Highbeam on position" there is still no lights. So now I have nothing
All the fuses are good - Underhood & Under dash. Everything else seems to work fine. I'm thinking headlight switch??? - Any other ideas?
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 02-18-2007 at 03:48 PM. |
02-18-2007, 04:37 PM | #2 |
Re: Need some Help (no lights): not '67-'72 but you guys know alot
What type of vehicle? switch on floor or column?
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
02-18-2007, 05:00 PM | #3 |
I am a Referee of life.
Since everything else works I would more suspect the dimmer switch.Hard to say though since you didn't tell us what vehicle.Could be computer controller on some of the new stuff.DRL's might make a difference too.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-18-2007, 05:05 PM | #4 |
Parts and more parts
Dimmer switch would be my choice.
02-18-2007, 05:22 PM | #5 |
Weekend Warrior
2000 Ford Escort (Junk)
H/L switch is on the column - it is on the blinker switch (twist it for P/L & H/L - and you push it forward to get High Beams, pull back for momentary Highbeams). Directionals work - push switch Up/Down - typical. Everything is on the same switch. The only "Dimmer" is the switch on the dash for the dash lights -
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 02-18-2007 at 05:24 PM. |
02-18-2007, 06:11 PM | #6 |
My Windstar did the same thing. There is a way to clean the internals of the all in one, but normally it won't last long before they act up again (ask me how I know??).
On the Windstar and F150 I had, you don't even need to remove the wheel to change the switch.
02-18-2007, 07:27 PM | #7 | |
Weekend Warrior
That just made my night - I was thinking about that earlier - "Man I hope I don't have to take this whole thing apart - but remembered from my body shop days that most of the newer ones have that plastic cover over the column that comes off. Is the verdict the switch???? -
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
02-18-2007, 08:18 PM | #8 |
I think it's the dimmer switch also. Good luck
69 Chevelle SS 375/396 TKO 600 71 Suburban 3/4 4x4 402 5-speed (project) 68 chevy C10 shortbed 327 5-speed (project) 72 Blazer 4x4 400 4-speed (wifes project) Numerous 67-72 parts trucks |
02-18-2007, 08:36 PM | #9 |
Weekend Warrior
"Dimmer switch" = Headlight switch??? (Everything is on one switch - H/L (High and Low), P/L, Directionals
02-18-2007, 10:37 PM | #10 |
Yes the hi/lo beam switch is the problem. I know I said dimmer switch which is what is on our trucks. I know late 80's early 90's Fords came apart easily but not sure about a 2000. I changed one on a 89 Ranger in less than 30 minutes. Everything runs off of the switch obviously. I am not sure that the hi/lo switch is not actually lower on the column.
69 Chevelle SS 375/396 TKO 600 71 Suburban 3/4 4x4 402 5-speed (project) 68 chevy C10 shortbed 327 5-speed (project) 72 Blazer 4x4 400 4-speed (wifes project) Numerous 67-72 parts trucks Last edited by Troy-Built; 02-18-2007 at 10:41 PM. |
02-18-2007, 10:53 PM | #11 |
I would say its the headlight switch. I work at a NAPA store and I've heard of it happening several times. NAPA offers a turn signal switch, but I believe its all in one piece. The part number is DL6373 if you want to take a look at it on napaonline. This part should work unless the car has factory fog lights.
03 ext cab stepside silverado bagged on 20's with some other cool stuff (daily driver) 1970 c10 short step just gettin started on it (project) |
02-18-2007, 10:58 PM | #12 |
It's actually called the Multifunction Switch...Most dealers stock those. That alone should tell you something.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
02-19-2007, 07:46 AM | #13 | |
Weekend Warrior
It's a F*@% - I already don't want to work on it as it is. Thanks for the part number "dailydragger" - I'll check it out today.
02-22-2007, 05:01 PM | #14 |
Weekend Warrior
Git-R-Dun
As much as I hate to work on newer Fords - this was an easy job.
Thanks for all the help with this guys: I changed the switch today and it solved the problem (I actually was playing around with the lights yesterday and jiggled the switch around and they came on so I knew that was the problem) Took me about 15min. Pop the top & bottom cover's off the column and change the switch: Ironically enough the switch I got was from AutoZone made by Wells (In the USA - Surprisingly) and it looked EXACTLY like the Ford switch - marking for marking. Ford was 2-3days wait @ $99 My Good Parts guy was 3-4days wait @ $80 NAPA was 3-4day @ $78 AutoZone was 1day @ $66 (and surprisingly US made) Advance - I called and the "English as a Second Lang." kid told me $3hundred something - I told him the Ford was only $99 and hung up.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 02-22-2007 at 05:06 PM. |
02-22-2007, 05:04 PM | #15 |
Glad it worked out. Yep My autozone switch (both times) lasted me over 3 years and may still be going on whoever has those old F@rds
02-22-2007, 10:53 PM | #16 |
glad to know autozone was best and cheapesr. i just strarted workin at one. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
