Old 02-18-2007, 06:46 PM   #1
Ram-Man
Ram-Man's Avatar
impala rear disc???
I know this topic has been around awhile but I got my brackets and finally got to the install and here is an issue that I ran into. I tried this on 2 rearends with the same problem. One is a 1971 12 bolt and one is a 1972 12 bolt. I also slid out the axles on and old rear end to try different axles but with the same results. I finally took the brackets off because I dont see how they will work. I know some hjave installed these calipers and are using them when I put the impala rotors on they run into the bracket before they sit flush on the axle face. It's obvious after looking at this all weekend the problem is in the axles not far enough out from the 4 hole flange The one axle I tried this on is a complete factory setup with no modifications done to it. Any thoughts??? Or does anyone have the measurement like in the picture to see if that is the problem. Thanks
Ram-Man is offline   Reply With Quote
Old 02-18-2007, 06:47 PM   #2
Ram-Man
Ram-Man's Avatar
Re: impala rear disc???
One more to show the axles in flush.
Old 02-18-2007, 06:55 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Does the bracket have an open side.I thought I saw one of these conversions and the bracket was inside of the flange.With my memory I could be completely wrong,especially since I have never done one.That seems like it would allow the rotor to fit in more and maybe fit the caliper.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-18-2007, 07:02 PM   #4
Ram-Man
Ram-Man's Avatar
These brackets didn't have an open side but they do now because I cut them to try them on the other side of the flange but that didn't work either.
Old 02-18-2007, 07:23 PM   #5
Inthuwind
Straight jacket required
Inthuwind's Avatar
I took my wheel off and snapped these~Hope this helps.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 02-18-2007, 07:29 PM   #6
Ram-Man
Ram-Man's Avatar
WOW inthuwind thanks for doing that. We have the same measurements from the flange to the back of the axle but I noticed your brackets are thinner I'll go measure my rotors.
Old 02-18-2007, 07:36 PM   #7
Inthuwind
Inthuwind's Avatar
Yeah, my plates are 3/16" I believe.
Old 02-18-2007, 08:37 PM   #8
Ram-Man
Ram-Man's Avatar
Here are pics of the rotor on. Now I can see we have the same set up but 3/8" plates are too thick to clear on this.
Old 02-18-2007, 08:41 PM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
A couple of things jumps out at me. Is the radiused corners hitting?....in other words, if I tighten up that corner where the OEM bracket bolts on, would it clear? And is the bracket hitting that small ring on the inner part of the rotor?
My thoughts are if some material could be milled off near the rotor, or cut the radius down where it touches the rotor. Whatever need to be done, whether it is reworking these brackets or making thinner ones, rest assured I will do whatever needs to be done to make it right!!!!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 02-18-2007, 08:50 PM   #10
Ram-Man
Ram-Man's Avatar
This is inthuwinds pic This spot here is a clearence issue with the size of the bolt heads. But the main problem is the plate thickness won't clear. I wonder if 383 stroker pic may have had a 67-70 housing which is narrower and used the 71-72 5 lug axle's. This would work out with this thick of a plate to get the clearence you need with the longer axle's and narrower housing.
Old 02-18-2007, 08:54 PM   #11
glock35ipsc
Inthuwind - could you please verify what the thickness of your plate is, and did you use metric or SAE bolts to mount the OEM bracket to yours and what size?
I'm thinking a socket head cap screw run from the outside towards the inside might help the clearance issue......
Thanks!
Bob
Old 02-18-2007, 09:13 PM   #12
Ram-Man
Ram-Man's Avatar
Thanks!
Allen-head would be the way to go, inthuwind said his plate were 3/16" thick.
Old 02-18-2007, 09:43 PM   #13
Inthuwind
Inthuwind's Avatar
Thanks!
Those would be great to use. Mine are SAE 3/8" bolts, and I had to turn the heads on the bolt to clear inside the rotor. Those round ones are ideal. I was thinking maybe your plate was thicker.
Old 02-18-2007, 09:59 PM   #14
Ram-Man
Ram-Man's Avatar
I think we have this figured out. I can see that yours are also tight inthuwind. But with the thinner plate it would clear. This is why we call it custom Now I hope glock can have some thinner ones cut out. Thanks for all the help inthuwind.
Old 02-18-2007, 10:02 PM   #15
glock35ipsc
If Inthuwind can confirm that his are 3/16", I will get them made ASAP!!!!
Bob
Old 02-19-2007, 09:06 AM   #16
Inthuwind
Inthuwind's Avatar
My plates are 3/16". What thickness are yours Glock?
Old 02-19-2007, 10:10 AM   #17
glock35ipsc
3/8". Simple failure on my part to double check fitment before sending them all out. I went off of this pic:
Bob
Old 02-19-2007, 10:15 AM   #18
Inthuwind
Inthuwind's Avatar
Have you sent alot out? Hopefully everyone will understand and not cuss at you~LOL. You've been a stand up guy in my book, hell you've been here on the board alot longer than I. Hope you get this worked out. Hey, that's not yours in the pic?
Old 02-19-2007, 10:59 AM   #19
glock35ipsc
Thank for the good words!!! I'm not out to hose anyone, just trying to help the shade tree guys like myself get stuff no one else has or makes. I have sent out quite a few sets, but that don't matter. I'll replace every one of them to make it right!
No, that pic is 383strokers. I used that pic to "guess" the thickness. My bad!!
Bob
Old 02-19-2007, 06:39 PM   #20
Inthuwind
Inthuwind's Avatar
AAAhhh that's right, that was his pic!! Thought it looked familiar. That's where I got my idea from LOL. Good luck Glock and Ram Man!!!
Old 02-19-2007, 06:42 PM   #21
Ram-Man
Ram-Man's Avatar
I really think what 383 stroker had was the 67-69 rear end housing and put in the 5 lug axles which are longer than what came with the 67-69 and some 70's. If you had that housing 67-69 you would be changing your axles to use the impala rotor. So the 3/8" thick plate would work in that case.
Old 02-19-2007, 06:49 PM   #22
Inthuwind
Inthuwind's Avatar
The axles were shorter weren't they?
Old 02-19-2007, 07:18 PM   #23
Ram-Man
Ram-Man's Avatar
That would be the ideal setup to get more clearence from the rotor to the bracket.
Old 02-19-2007, 10:33 PM   #24
glock35ipsc
It appears that using the earlier (shorter) housing with the 71 and up axles (longer) would yeild enough clearance for the 3/8" plates.
Bob
Old 02-20-2007, 12:47 AM   #25
action
Active Member
action's Avatar
I also bought the brackets from Glock ( Nice pieces) Anyway it will be a while untill I use them but it looks like just a little clearnceing (SP?) will do the trick.
I hope it all works out.
Jack
68 Chevy Long utility bed.
Now swb/Bagged
Soon to be 468 (Maybe 496) BB/Turbo 400
action is offline   Reply With Quote
