02-18-2007, 07:01 PM | #1 |
BK Built
Newer steering column swap?
so in my panel, i had an 87 firebird tilt wheel and column in it, but it took a bit of work to make fit and work correctly. i remember seeing somewhere that people use like full size van columns or something, and i was curious if anyone has any info on that. thanks in advance guys.
02-18-2007, 08:55 PM | #2 |
Re: Newer steering column swap?
Chevy vans up to 1980 I believe.. It still takes some work to get them.. Just not as much... I just put an 88 suburban column in my truck.. It will have the highbeam switch and wiper switch in the column as well.. I will be using the harness also.. If I can get the wiper motor to work the delayed wipers will be in effect also...
02-19-2007, 01:04 AM | #3 |
BK Built
and how hard was that to mount up, such as mounting it to the underside of the dash? any pics? i liked the firebird column because it was short and small wheel(needed when i have a 12" windshield like on the panel) but the truck isnt getting chopped.
02-19-2007, 01:41 AM | #4 |
check out this article here.... a guy used aa '83 suburban for donor parts to put it in his '65 chevy truck... lots of pics and how he did it.
---- Power Steering and a Tilt Wheel for the '65 I picked up an '83 Suburban that came from Wisconsin and was pretty much a rust bucket. This is the source of all the parts I used to add power steering and a new tilt steering column. The whole this was incredibly easy as you will see. http://www.persh.org/pickup/steering.htm -------- -W |
02-19-2007, 02:05 AM | #5 |
sweet my cadi column didn't fit but that gave me some hope!!! good stuff thanks
02-19-2007, 10:51 AM | #6 |
Pretty much How Pershes page.. Only thing is I have short arms.. hehe.. Also I had to cut the mounting bracket to accept the high beam switch which is mounted to the column... I will be using the ignition on the column also.. I put the wheel at a comfortable distance for me.. Now I just need to finish it off.. I am now in the process of mounting up the 68 power brake booster I got at the yard the other day...
