Old 02-18-2007, 11:06 PM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Need Prop valve -> Frame block Lines
Except mine are routed outside of the frame, anyone know where I can find a set like this? LMC says a low number of 67-69's were outfitted with this style of line from the factory...
Any vendor have these in stock?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 02-18-2007, 11:26 PM   #2
rage'nrat638
rage'nrat638's Avatar
Thumbs up Re: Need Prop valve -> Frame block Lines
try gmcpaul he's a site vendor here
http://www.gmcpauls.com/
rage'nrat638 is offline   Reply With Quote
Old 02-18-2007, 11:36 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Already looked, cant find them.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 02-18-2007, 11:42 PM   #4
rage'nrat638
CALL LES TOMORROW
he's a man of many virtues. if it's made he can get it..
Old 02-18-2007, 11:58 PM   #5
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
CALL LES TOMORROW
Les?
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 02-19-2007, 12:39 AM   #6
rage'nrat638
LES WORKS WITH PAUL
Old 02-19-2007, 09:53 AM   #7
70c10
67-72 Addict!
70c10's Avatar
The prop valve is for disc brakes and the "junction block" is for drum brakes. I'm assuming you are needing the junction block because you have a 69?.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-19-2007, 02:31 PM   #8
e rock
Can't you just make the correct lines? IMO, being able to put a clean double flare on a brake line is an invaluable (and relatively easy to learn) skill.
e rock is offline   Reply With Quote
