Old 02-19-2007, 12:39 AM   #1
dave2953
Dave's not here, man
dave2953's Avatar
U-Bolt Torque
I just installed my Super Track Bar and the torque specs for the u-bolts is 215 ft. lbs. My torque wrench only goes to 150, so I torqued them to that. Will this be o.k. and has anybody else had a similar issue?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-19-2007, 01:10 AM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: U-Bolt Torque
I would think so,but to be sure you could put a ratchet on there of the same length and tighten with a force about 1/3 greater than what it took to get to 150.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 02-19-2007, 01:33 AM   #3
jimmydean
jimmydean's Avatar
Re: U-Bolt Torque
I put a breaker bar and wrenched them as tight as I could. They are tight, but I'm not too sure how tight because I have the same issue. It took everything I had to get them off (I don't have an impact) so I doubt I can over tighten them.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-19-2007, 05:22 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: U-Bolt Torque
just put them as tight as you can get them, we did that on the the race car and the axle hasnt moved from where we put it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-19-2007, 07:46 AM   #5
dave2953
dave2953's Avatar
Re: U-Bolt Torque
Thanks for the input guys. It took everything I could muster just to get it to 150. I didn't see how they could come loose, but I thought I would ask those who know just in case.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 02-19-2007, 09:46 AM   #6
WorkinLonghorn
Re: U-Bolt Torque
In cases like this I have a length of galv.pipe I put over my breaker bar and make a 2' handle then divide the torque figure 1/2.For 215 I would just imagine how much effort it would take to lift 107 lbs.and apply that to the 2' handle.Or make a 3' handle and pull 70 lbs.This will also weed out the Chinese breaker-bars and sockets from your tool box as they will break at about 120 lbs.
Old 02-19-2007, 11:22 PM   #7
sleepyboy
'69 Step
Re: U-Bolt Torque
Tried to get my u bolts off this weekend; went through 2 1/2" socket wrenches until Mr. Sawzall had to come to the rescue..amazing what 35 years of grime will do to bolts.
sleepyboy is offline   Reply With Quote
Old 02-20-2007, 10:27 AM   #8
WorkinLonghorn
Re: U-Bolt Torque
Did you soak them with penetrating oil first?
Old 02-21-2007, 05:08 PM   #9
sleepyboy
'69 Step
Re: U-Bolt Torque
3 days
Old 02-21-2007, 05:57 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
Re: U-Bolt Torque
I have always set mine with the 1/2" drive air impact and to this day, no problems. That is on five different trucks.
piecesparts is offline   Reply With Quote
Old 02-21-2007, 08:18 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: U-Bolt Torque
If you do much heavy work like this a torque multiplier is a wise investment.I don't have one but have used them at work to set torque as high as 900 ft lbs.They are gear reducting so you do have to have room to swing the handle of the torque wrench.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
