Old 02-19-2007, 02:26 AM   #1
supermuble
LT1 internally balanced?
I am considering purchasing a 1994 LT1 350 from a friend. He rebuilt the engine himself, oversize pistons, new connecting rods, and a new crankshaft. All brand new OEM replacement parts. The machine shop that did the work said it didn't need to be balanced that the parts were "factory" spec. The engine is hooked to an automatic transmission, previously a 4L-60E, now a 700R4.
Are these engines internally balanced or externally balanced?
The engine runs and it is smooth, no noticeable vibrations can be felt or heard, but I don't want to cause long term damage.
I learned turbocharging the hard way. I turbocharged an ancient import! The theory still applies to the Chevy engine. http://www.angelfire.com/planet/celica
supermuble is offline   Reply With Quote
Old 02-19-2007, 02:39 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: LT1 internally balanced?
i think there internal bal. but what are oversize pistons ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 02-19-2007, 02:53 AM   #3
FarmTruk
In Memoriam...
FarmTruk's Avatar
I believe when the LT1's switched to 1 pc rear main seals, the General changed to internal balance. However, the internals are lightweight, so any changes, such as "over-size pistons" could throw the factory balance off.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-19-2007, 05:19 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
over sized pistons would be if the block is .30 over or more then the stock pistons dont fit and you need new pistons that are bigger than stock
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-19-2007, 10:41 AM   #5
cooters
all 350s were internally balanced, 400s were enxternaly balanced (smallblock) however balancing is nice but not required in your case unless you are going to rev it to 6000
cooters is offline   Reply With Quote
